Installing SFC's
Old May 11, 2003 | 12:33 PM
DaveL's Avatar
Installing SFC's
I want to get a set of SFC's, I'll probably go with the boxed BMR weld-in's. I would like to do the install myself since my father bought a welder, but we don't have a lot of experience welding. I viewed BMR's online instructions and it doesn't look that hard to do, or is there more to it? Should I do the work myself or look for someone to do it for me? Does the install require removing anything inside the car such as the carpet? Will I have to reposition any fuel lines? Thanks for your advice.
Old May 11, 2003 | 12:59 PM
Mikael's Avatar
I'd practice before you start on this. Go to home depot and get some steel plates, and practice on that.
Once you're good, go at the car. Its pretty simple- jut make sure the surfaces are clean. There is already a shield for the fuel line, so you should be fine.
Old May 12, 2003 | 09:30 AM
bbentley40's Avatar
The carpet should not be a problem either. Just remember that is it there and becareful of how much you weld in a certain spot. If you mix it up some with the welding you will not have any problems at all. Just make sure you have a way to get the car level AND under load. I installed my SFCs with the help of a friend and my fiances dad (he did the welding). We just used 4 identical ramps so the car was sitting up in the air but was level and under load. Also if you are thinking about doing LCAs now is a perfect time. Is is so easy to do the SFCs and LCAs at the same time, that is what I did.
But I would agree with Mikael, get some practice first!!
Nov 18, 2023 07:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
