installing new aluminum DS?
Old Dec 10, 2002 | 07:46 PM
camaro98_speed's Avatar
Question installing new aluminum DS?
I have an 1le aluminum driveshaft and I am going to install it on saturday. I was wondering if I am going to need to add any tranmission fluid to the tranny after installation? Im going to jack the rear-end up as far as I can go, so gravity forces the fluid towards the front of the tranny, and then pop out the DS out of the tranny, hopefully not loosing too much fluid. I was wondering If I still needed to put some in afterwards?
jp
Old Dec 10, 2002 | 08:40 PM
PhantomTA's Avatar
Moderator
your car have one of the steel driveshafts i take it? I only ask this because i had a guy tell me that he swaped a 1LE shaft with his stock aluminum shaft because the 1LE was better.. it was quite humorous since its the same driveshaft.
you will not need anything for the swap
Old Dec 10, 2002 | 09:04 PM
Wait? the 2002's come with a aluminum DS? I have no clue, I just assuummed that it came with a 1 piece steel. Is there a code on the door that could should tell me whether or not it has a steel or aluminum?
jp
Old Dec 10, 2002 | 09:11 PM
96SFLZ's Avatar
Yeah, that's what Dave was telling you, '98+ have an aluminum DS...stock.
Old Dec 11, 2002 | 09:03 AM
Loudmouth LS1's Avatar
Not all, I have a '99 Z28, and it's got a steel DS. Just look under there, if it's all rust lookin and stuff, it's steel. If it's clean it's aluminum.
Old Dec 11, 2002 | 09:08 AM
PhantomTA's Avatar
Moderator
if you have a speed limiter then you have a steel one..
Old Dec 11, 2002 | 09:09 AM
bsmith's Avatar
I seem to remember reading that cars with 2.73 gears have steel driveshafts and cars with 3.23's have aluminum. Is that not correct?
Old Dec 11, 2002 | 12:07 PM
tomslawsky's Avatar
2002's ALL have the al. Drive shaft
Old Dec 11, 2002 | 04:11 PM
tomslawsky's Avatar
Originally posted by robvas
I have an A4, 2.73's, no speed limiter.
I have a steel driveshaft. I wouldn't mind picking an aluminum one up locally.
BTW, they're a cinch to put in. Just jack the car up enough to get under it, undo the u-joint, pull it out, and reverse for your new one.
They can be a bit of a pain to shove back in there, with the exhuast and torque arm in the way.
I stand corrected....I guess the 2.73's get steel...sorry!
Old Dec 13, 2002 | 10:47 AM
Jerm93z28's Avatar
are you talking about an LT1 1LE shaft? those are a larger diameter than an LS1 shaft and a good bit stronger.
jeremy
Old Dec 13, 2002 | 12:51 PM
Im not sure. here is the part number 10085375, I got it from gmpartsdirct.com for like 219 dollars. I had it in on my 98 v6 camaro.
Old Jan 16, 2003 | 11:12 AM
GPZ1100's Avatar
For the driveshaft installation, does one reuse the old bolts at the differential, or replace those?
(the 4 bolts I believe holding the rear u joint to the rear end)
Also, is there a torque spec for these bolts?
Old Jan 16, 2003 | 11:42 AM
Jerm93z28's Avatar
reuse the bolts, but im unsure of the torque specs.
jeremy
Old Jan 18, 2003 | 11:14 AM
gillbot's Avatar
the 273 cars come with steel shafts, not alum. I got a lingenfelter alum to replace my steel one a while back.
Old Jan 18, 2003 | 02:06 PM
2002 NBM Bird's Avatar
2.73 gearing get the steel shaft, others get the aluminum shaft
