installing FAST 78
Old Feb 8, 2013 | 12:42 PM
Ultra_Z's Avatar
installing FAST 78
Are my stock injectors/fuel rail etc all able to swap over with no additional modification needing to be done? Is it down and dirty swap over plug & play?
Thanks in advance
Old Feb 8, 2013 | 03:38 PM
bluz28's Avatar
Re: installing FAST 78
Yeah, the injectors/fuel rail will swap right over, but first blow-down the top of the engine. I'd also replace the injector O-rings, and valley cover bolts with shorter heads, plus install LS6 intake front coolant tube an rear block offs, and new port seals.
Old Feb 8, 2013 | 06:22 PM
Ultra_Z's Avatar
i should have the ls6 coolant tube and rear block offs bc i've already upgraded to 243 heads...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
maybe2fast
Feb 5, 2015 05:14 AM
birdblack
Dec 30, 2014 06:59 PM
