installed ssra is there supposed to be a gap?
Old Apr 25, 2004 | 12:39 PM
bluecmaro96's Avatar
where you push the bottom piece into the top piece it will only go so far then the piece for the hood latch stops it from going in any farther. there is about a 3/4 inch gap in the middle but the sides are in the whole way, is this supposed to be like this? im sure the air can still flow through but it seems since there is a gap in the middle where the two pieces slide into eachother that this isnt sealded the whole way across? will this be ok? thanks
Old Apr 25, 2004 | 12:54 PM
bombd84's Avatar
Yeah mine is like that to, its like a slot in the middel for the radiator support or whatever that metal V shaped piece is.
Old Apr 25, 2004 | 01:43 PM
teke184's Avatar
it's just the way it is designed around that latch support.
think of it this way, it will help prevent possible water being sucked up...since it isn't 100% sealed.
it won't affect the funtion though.
so how do you like the gains from the unit?
Old Apr 25, 2004 | 01:45 PM
Flat_Tire_'s Avatar
Were you guys able to remove the lower radiator shrowd by pulling out those three fastners? I couldn't get em to save my life so I left it in ... going to cut the thing out with a dremel eventually.
And does the top backside of your SSRA unit touch/press against the the radiator behind it (what is that the transmission cooler?)
Old Apr 25, 2004 | 02:01 PM
those fatseners were a pita, i did get them i used a flat screw driver and pryed like crazy till it popped off, hope this helps, im not sure if that is the ac cooler or the stock tranny cooler. when i screwed my ssra into the bumper i pulled out and did it and it isnt touching.
mullettour's Avatar
Probably the a/c condenser.
Old Apr 25, 2004 | 02:12 PM
Flat_Tire_'s Avatar
I'm guessing when I get that lower shrowd out there will be more room for the SSRA to angle forward and then it will no longer press against the A/C condenser ... Think it's hurting anything pressing against it now? I never even use A/C in my car hehe .. windows down all the time.
Hey Josh, just saw the time in the sig ... Very nice!
Old Apr 25, 2004 | 04:02 PM
teke184's Avatar
i found using a pair of wire clippers works good on fasteners like that.
they slid in under the "head" and you can leverage them out
as for touching the radiator, mine doesn't...it come close but doesn't touch that i can think of.
Old Apr 27, 2004 | 08:27 AM
birdmanz28's Avatar
SSRA install
yes its the radiator and it does touch it.. i was kind of mad about it at first because it seemed cheap when I installed mine.. but it hasn't made a difference so far.. jus be careful when installing not to push too hard against it and damage it. It definatel a tite fit
Nov 18, 2023 07:21 PM
jayblev95
East South Central
Feb 15, 2015 02:26 PM
1963SS
Feb 6, 2015 10:05 AM
jayblev95
Jan 6, 2015 11:52 AM
