Installed SLP lid and wont start...
Old Jul 10, 2003 | 12:01 AM
mystic98Z's Avatar
Angry Installed SLP lid and wont start...
My car wont start now after installing the SLP lid and a K+N filter. I disconnected the battery before changing anything and then connected it last after everything was done. It doesnt make sense. Has this happened to anyone else? what could it be? The first time i tried starting the car there was a quick starter noise but only lasted for a second before it stopped. 2nd time around there was no response from the car at all.
Old Jul 10, 2003 | 12:08 AM
Ferocity02's Avatar
This happened to me too after my gauge install. The starter would like click then all power would die. Tighten down the battery terminal really tight. Not so tight you break them, but tight. This fixed the problem. If that doesn't work, get some sandpaper, and sand the terminals on thr battery and on the wires. The starter pulls so many amps that if the contact isn't good, it won't work. Hope this works.
Good Luck!
Old Jul 10, 2003 | 12:18 AM
mystic98Z's Avatar
ok I got the car to start after fiddling with the battery a little bit and giving it a jump. THanks for the post!
Old Jul 10, 2003 | 01:10 AM
Ferocity02's Avatar
Cool, your in Sacramento, I'm about 20 minutes away
Glad I can help, if I did
Old Jul 10, 2003 | 11:11 AM
XTZ's Avatar
XTZ
There is no reason to disconnect the battery for changing the lid and filter. It sounds like the terminals just needed to be tightened.
Nov 18, 2023 07:21 PM
QuickSilver02
Apr 7, 2015 11:12 AM
rjc1629
Jan 27, 2015 10:46 AM
Mad_Ice
Jul 29, 2002 09:44 PM
