Ignition Modifications???
What could I do to boost my ignition performance? Would I see any benefits? What type of Performance parts would I need?
I am open to any suggestions!!!!
My ignition at the present time is stock so I figured anything would help....right?
You could change your plugs and plug wires if you really wanted to.
Upgrading your ignition would not be worth it. You won't see any gains at this point. The stock ignition is pretty good. If you had 150k miles or so, I'd say go for it. Also, if you were running some large doses of nitrous quite often, then it probably wouldn't hurt to upgrade. Otherwise, spend your money elsewhere. I'm no expert, but that's my opinion.
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
