Idle surging issue
Old Feb 3, 2012 | 09:35 PM
z28camaro1090's Avatar
Idle surging issue
Can someone help me mods as below. Idle surges sometimes not all the time 2 or 300 rpms. And sometimes it will do it in drive but not neutral or park or vise versa. Also, it has been doing it since before I got my ls6 intake put on, and has continued to do it after. Mods are below in the sig. Ive cleaned everything Mass air, changed fliter, fuel filter.Also, I sprayed carb cleaner around intake and hoses to see if it changed the idle it did not. It's really starting to bother me Id appreciate some help from someone? thanks guys I thought it might be a intake leak but the chances it is on both intakes is slim I think.. any other ideas appreciated.. I cleaned the IAC as well
Old Feb 4, 2012 | 05:10 AM
rod442's Avatar
Re: Idle surging issue
Is it doing it becuse the ac or defrost setting is on?
Old Feb 5, 2012 | 01:30 AM
It does it both if i turn the AC off or on or whatever I do. Its real random
Old Feb 6, 2012 | 09:53 AM
whitdog54's Avatar
do you have a different TB on there? maybe a ported and polished one? I would check all the vac lines, could be some small little vac leak.
is the car tuned?
Noenav
Mar 1, 2019 07:38 AM
edman
Mar 13, 2015 09:39 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
grgguy
17
Feb 23, 2015 07:57 PM
David Dorris
Jan 17, 2015 08:10 PM
