Idle fluctuates a bit
Old Feb 13, 2007 | 09:52 PM
MasterEvilAce's Avatar
Is it normal for the idle to fluctuate a bit.. and maybe even stumble a slight bit, in these cars? For instance, completely stopped, car in neutral.. the tach needle will barely jiggle, but it's noticable if you watch it. And the shifter vibrates a bit as well, with the engine. It seems like it's a stable idle, with an occasional "blip" in it..
Thinking maybe the IAC port might have some carbon, or something in it. I'm not real sure. It might just be normal, as well.
Old Feb 14, 2007 | 08:20 AM
AL SS590 M6's Avatar
Moderator
normal
Old Feb 14, 2007 | 11:09 AM
SSpdDmon's Avatar
Nice car...
Old Feb 14, 2007 | 01:46 PM
2001NBMZ28's Avatar
Sounds normal. If you watch the RPM's on a scanner they actually fluctuate a little - in neutral my A4 switches between 645-676 after warmed up.
Victor Lamb
Aug 26, 2017 02:52 PM
ChrisFrez
Mar 1, 2015 01:33 PM
Alex Barnes
Jan 24, 2015 10:21 PM
edman
Jan 22, 2015 02:45 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
