I need help w my coolant level sensor!!
Old Feb 22, 2006 | 05:49 PM
DeadMaul's Avatar
I have a 1998 Camaro z28 and the previous owner take of the connection of the coolant level sensor and i dont know where can i plug it again, so i need a photo o some info taht help me doin that. ( a photo of the conection realy gonna help me)
THX
Old Feb 23, 2006 | 07:21 AM
AL SS590 M6's Avatar
Moderator
Re: I need help w my coolant level sensor!!
THX
The sensor is in the radiator just under where the upper hose goes in.
Old Feb 23, 2006 | 07:31 AM
teke184's Avatar
yep...
on the engine side, just under the fill cap.
you can try removing the sensor and cleaning it. some people say that does the trick for a while, instead of unplugging it or replacing it.
Old Feb 23, 2006 | 10:31 AM
DeadMaul's Avatar
Thx you guys but my really question is the other side of the conection, because the wire its plug in the radiator but the wires are cut and i dont find the other part to reconnect.
Old Feb 24, 2006 | 05:40 PM
angel71rs's Avatar
Honestly, I wouldn't bother. The coolant level sensors are such problems they quit installing them in later years. I disconnected mine, just check the level when I check the oil. JMO
Old Feb 27, 2006 | 08:30 AM
DeadMaul's Avatar
Ok Thks Guys.!
Old Jun 20, 2010 | 12:45 PM
Boston_Bob's Avatar
how to replace the coolant level sensor 1998 Z28.
1 lower coolant level.
2 remove the battery.
3 this will give you a clear view of the sensor on the radiator tank on the passenger side.
4 remove the plug from the sensor.
5 remove the metal spring clip that holds the sensor to the radiator tank.
This is easily reached and removed with the battery out of the way.
6 Now pull the sensor straight out push the new one in and hear it clip on.
7 plug in the sensor and re-install the battery.
Old Jun 21, 2010 | 08:11 AM
Marc 85Z28's Avatar
6 now pull the sensor straight out push the new one in and hear it clip on.
Did you sign up just for this advice? THIS THREAD IS OVER 4 YEARS OLD.
Old Jun 22, 2010 | 04:40 AM
johnny6's Avatar
OP's last activity date: 01-13-2008
I think he's got the problem resolved......
Old Jul 12, 2010 | 11:32 PM
TMDZ28's Avatar
Good thread. I think this will help me in the future.
Old Oct 3, 2012 | 04:52 PM
Johnny Ray's Avatar
Freebird
It just helped me right now!
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
