I know what cam Im going with.......
Old Aug 4, 2002 | 05:20 AM
Sparkz28's Avatar
Cool I know what cam Im going with.......
Im am going to go with the GM Ls1 hot cam and the Jessel 1.75:1 shaft rockers and some comp cams springs..Im going to use this setup because I can do it for under $1,000 bucks.....My goal is 400rwhp with stock heads...so,anybody think it can be done?
94 Z28 m6
cold air,air foil,b&m ripper,vortech tb elbow,underdrive pulley ,flowbasterd muffler,moded maf,poly trans mount,fuel pres reg,exhaust cut out........new mods 355/with 12# of procharger boost
99 Camaro SS m6
#133
MTI air lid,some free mods,B&M Ripper,MacEwen Motorsports WFG with no high beam thingy....slp longtubes w/o cats,zo6 maf,z06 clutch,jet pcm,qt cut out
Big Red(truck)
406 ci,700r4 w/3000 rpm stall,3.73 10 bolt.
No more 406..kaboom / on the way 427 mighty mouse
Old Aug 4, 2002 | 02:44 PM
redz_02's Avatar
Post
Check out www.thunderracing.com, maybe with one of their cams and some longtubes, larger mass air, and bored throttle body you may reach that number. The reason i put thunderracing is b/c they put some dynos with the cams.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
Borla (the expensive cut-out), Wisperlid W/K&N, FRA, Cags eliminator, Strange 4.10's, G2 Rear Girdle, Valv. Synthetic 10W-30, Redline gear oil, Fat hurst shift ****, Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev K2's, Focal utopia 6" audiom midrange.
Old Aug 5, 2002 | 05:39 AM
TA2001's Avatar
Post
Take a look at these cam setups and see if
there is one you like,
http://ls1info.com/camstats/showdata.php
got a cam installed and want to list it
go here
Old Aug 5, 2002 | 11:35 AM
JurisAg02's Avatar
Post
400 RWHP can be and has been done quite a few times allready on stock heads. I however do not see it happening with a Hotcam and RR or whatever. My choice, if stock heads was my plan, would be to use the new "reverse split pattern" cams that are available through Thunder Racing.
Rick
Old Aug 5, 2002 | 11:44 AM
Trevor98ramair's Avatar
Cool
What's the reason for changing the rockers? The stock ones will work just fine with a cam swap. Also, there's not a chance that you're hitting 400 RWHP with the Hotcam. I've seen over a dozen graphs on Hotcammed cars, and the best I've seen is 372 RWHP with the average being in the mid-360's. These are all M6 cars, too. I would highly recommend stepping up to a better cam. I have a 224/224 Comp XE-R grind in my auto, and it idles quite a bit better than a hotcam does. It also makes more power. (361 RWHP unlocked, 380 RWHP locked). 380 RWHP with stock heads through an A4 isn't too shabby. The last car that left our shop with the G5 cam put down 390 RWHP to the wheels with stock heads, FYI. If you are wanting something other than the G5, then we can get it for you as well. Just give me a call at the shop, and I can help you out.
Trevor - LGM
'02 SS: 11.63 @ 114.06 MPH, 1.588 60'; 3,515# raceweight, 1,102' D.A.
naturally-aspirated with bolt-ons, a cam, and a fat converter!
L.G. Motorsports (972) 272-7753
Check out the SS!
[This message has been edited by Trevor98ramair (edited August 05, 2002).]
Old Aug 5, 2002 | 07:48 PM
JurisAg02's Avatar
Post
The reason he wants a diff rocker ratio is to gain more lift from the Hotcam...hence more power, but money to horse ratio its still a bad decision...
Well, the G5 cam makes real good peak numbers but do a search for track results on it and you will see thats all that cam does...peak numbers, the only person to run well with it is Bear on ls1tech.com from what I have seen. The TR224 will give you more power and better ET honestly IMO. One of my buddies runs a G5 cam with MTI S2 heads and he still gets smoked by B1 guys left and right lol
Rick
[This message has been edited by PhatT/A (edited August 05, 2002).]
Old Aug 6, 2002 | 05:57 AM
Sparkz28's Avatar
Post
Trevor.....any thing to say about that?
94 Z28 m6
99 Camaro SS m6
#133
Big Red(truck)
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
