hypertech powerstat wont fit????????
Old May 19, 2007 | 09:37 PM
Snugans310's Avatar
Unhappy hypertech powerstat wont fit????????
I have a 2002 camaro ss with an ls1 i got the hypertech powerstat part #1014 but it wont fit the thermostat is to big to fit whats going on i need help
Old May 19, 2007 | 09:42 PM
Bayer-Z28's Avatar
There is a certain way the stat fits into the housing.. It slides under a couple tabs IIRC...
Would that be the problem? I got a new housing w/ mine..
EDIT; just looked at my stocker.. The install should be fool proof..
Old May 19, 2007 | 09:44 PM
Snugans310's Avatar
i got the housing as well but it wont fit man the metal part that hold the thermostat are too wide
Old May 20, 2007 | 12:47 PM
blacknight's Avatar
Did you any or a previous owner change out the waterpump? If so then you need a different thermostat. The newer ls1 water pumps are different. You can get the correct thermostat from Slp or Jegs. This one http://www.jegs.com/webapp/wcs/store...0002_316698_-1
Old May 20, 2007 | 01:26 PM
2001NBMZ28's Avatar
Yep, the 1014 won't fit the new style replacement water pumps.
Dragonballz28
Sep 10, 2002 01:45 PM
Dragonballz28
Aug 31, 2002 09:37 PM
slothgrant
Aug 22, 2002 03:01 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
