Hypertech???? Or Chip?????
Would it be better to buy a Hypertech and tune manually( and hope i dont screw up) or take my car to a place by me (Street and Performance electronics) and have them put a chip in. or is the hypertech pretty user friendly??? And would it be good to but the 160 thermostat along with it????
99Z28RS(A4)Navy Blue Metalic
SLP LoudMouth
SLP Air Temp Module
MTI Carbon Fiber Air Lid/K&N
EGR Mod,FRA Mod
-Future Plans-
SFC's
Strut Tower Brace
Shocks/Springs
Torque Converter
SLP LoudMouth
SLP Air Temp Module
EGR Mod,FRA Mod
-Future Plans-
SFC's
Strut Tower Brace
Shocks/Springs
Torque Converter
Anyone????????????
SLP LoudMouth
SLP Air Temp Module
EGR Mod,FRA Mod
-Future Plans-
SFC's
Strut Tower Brace
Shocks/Springs
Torque Converter
SLP LoudMouth
SLP Air Temp Module
EGR Mod,FRA Mod
-Future Plans-
SFC's
Strut Tower Brace
Shocks/Springs
Torque Converter
Well, these cars can't get a chip installed because they are permanetly soldered to the PCM. Unlike the 3rd gen years and '93 F-bodies. You can either run Hypertech (programming sucks on mod'ed cars), custom tuning by an experienced shop, LS1-Edit (tune it yourself) or get a plug-in module (similar to HPP3, not like a chip).
George P. Lara
1984 Z28
2001 SS #0391
SCCA, SC3G, GS3, SCFB, SSOA #M01-0391
[This message has been edited by MRZ28HO (edited August 12, 2002).]
George P. Lara
1984 Z28
2001 SS #0391
this is one of those things that bother me
Hypertech is useless...
get a dynotune or www.PCMforless.com or LS1 edit
all with the exception of dynotune cost less and do a whole hell of alot more
dynotuning is alot of money but the best
you dont need any, and bang for buck i'm callin PCMforless
if you do decide to go that route, shoot me an email, i can get you free shipping ($15 or so, no biggie)
On a light bolt-on automatic, the Hypertech is NOT useless. Being able to adjust your shift points, alone, is worth it! There's a tenth or more to be gained in shift points, at times, because they're so bad from the factory. My stock 1-2 shift point was at a measly 5,400 RPM! Being able to fine-tune your shift points at the track is a big plus. You can also kick your fans on earlier, raise your rev limiter, adjust for gear or tire height changes, remove your top speed limiter, etc. The power tuning will work fine if you run premium gas and install a 160 t-stat. The high cost of custom dyno tuning is NOT warranted on a car that is mostly stock.
Trevor - LGM
'02 SS: 11.63 @ 114.06 MPH, 1.588 60'; 3,515# raceweight, 1,102' D.A.
naturally-aspirated with bolt-ons, a cam, and a fat converter!
L.G. Motorsports (972) 272-7753
Check out the SS!
Trevor - LGM
Check out the SS!
