Hurst shifter question? Help? Help?
Old Sep 9, 2003 | 07:53 PM
DarksideII's Avatar
Any of you great camaro guys that have a factory installed Hurst shifter tell me if your shifter handle says"Hurst " on it anywhere? Did they ever come that way? TIA
Old Sep 9, 2003 | 08:04 PM
crazyswede1027's Avatar
my formula has a large H on top of the shift *** to designate it is a hurst shifter, which came that way from the factory. I believe camaro's came with the same.
Old Sep 9, 2003 | 08:15 PM
DarksideII's Avatar
Thanks, that makes sense, but I don't believe the shifter rod says "hurst" on it? That's what I am trying to find out. I am pretty sure these shifters were made by Hurst for SLP?
Old Sep 9, 2003 | 10:07 PM
SSpdDmon's Avatar
I just swapped out my pos stock shifter for a factory installed Hurst that my friend sold me for $20. The one thing I noticed that threw me for a loop was, both shifters used identical rods/handles. The difference was in the base. The Hurst can be disassembled easily with an allen wrench and has a few springs in it. It also has a thicker base than the stock shifter. If you're still not sure what ya got, go get a Pro 5.0 or a Ripper and you'll know for sure.
Old Sep 9, 2003 | 10:12 PM
Lan01z's Avatar
Re: Hurst shifter question? Help? Help?
Mine just has the H on the ****. I took the boot off once and it doesnt say anything on the handle. I'd imagine if you got a shifter from hurst, they would just put a little hurst logo sticker on it.
Old Sep 10, 2003 | 01:20 AM
67 LS-1 & T-56's Avatar
My hurst shifter has a chrome shaft with the "hurst" insrcibed down the side. The shifter is angled toward the driver, and the **** is black with the gear selection pattern on it. I actually bought it off of this site about 2 years ago
-gordon
Z28-50
Parts Wanted
Feb 21, 2015 09:00 PM
Jazsun
Dec 29, 2014 12:14 PM
slocody
Feb 10, 2003 01:04 PM
kurob25
Aug 5, 2002 08:03 PM
