how much power
Old Feb 9, 2007 | 08:03 PM
  #16
teke184's Avatar
in case you were wondering...the LS1 comes stock with roller fulcrum 1.7 ratio rocker arms...
so new rockers would make a minimal improvement.
oh and not knowing much about the specifics of that particular cam...i'd guess on an automatic...that setup would give you 430rwhp
Old Feb 9, 2007 | 08:37 PM
  #17
burn's Avatar
the reason i put new rockers in there is that trick flow told me that i would need new rockers from crane but the same ratio
Old Feb 9, 2007 | 10:30 PM
  #18
AL SS590 M6's Avatar
Moderator
Originally Posted by burn
what do you think of this combo
trick flow heads 215cc
trick flow stage 3 cam lsa 112 228 230 @.5 .585 .585
fast intake
90mm throttle body
new 1.7 rockers
jet hot long tube headers
yank 3200 stall
motive 3.73 gears with new locker
and dyno tune
All cool except not enough stall
Old Feb 10, 2007 | 08:42 AM
  #19
teke184's Avatar
never heard of needing new rockers with the TF....odd
Old Feb 10, 2007 | 08:52 AM
  #20
JakeRobb's Avatar
Super Moderator
Originally Posted by lastZ
well if its an 02...you probobly have the ls6 block.....and it will handle that much power easy....as far as the cam and heads....ill let someone else chime in
So much misinformation... GAH!
The LS6 and LS1 blocks are nearly identical. The LS6 has some additional windows for better bay-to-bay breathing. That is all. The LS1 block is actually preferred by guys making lots of power; better yet is the iron version found in some trucks.
2001 and 2002 cars have the LS6 intake manifold, which is worth ~5hp horsepower on a stock motor, and more on a modded motor. The FAST intake is even better.
Anywhere above 400rwhp and the thing you really need to worry about is your rear end. It'll probably be fine if you baby it, but if you want to do any hard launches, you can safely bet on shearing teeth off the pinion or ring gear in your future. That's another conversation, though -- do a search in the Drivetrain forum for more info.
Old Feb 11, 2007 | 12:00 AM
  #21
Ripper415's Avatar
good info bayer, i've been wondering for a while how to tell if i had the ls6 block or not. guess i'll have to go head outside with a flashlight.
Old Feb 11, 2007 | 03:28 PM
  #22
danziger's Avatar
A stock bottom-end will handle 576rwhp all day long...ask me how I know.
Old Feb 27, 2007 | 02:15 PM
  #23
ev95355's Avatar
Do tell???
Old Mar 1, 2007 | 01:59 PM
  #24
danziger's Avatar
Originally Posted by ev95355
Do tell???
Been there, done that, got the dyno sheets.
FWIW, I recently went with a forged 383 and the guy that bought my old motor said it looked great! Well, except for a bent valve from me spinning it a smidge too high...
Old Mar 1, 2007 | 07:49 PM
  #25
YBNORMEL's Avatar
All in the tune, push the A/F to the limit and say goodbye to the #7 ringlands.
Old Mar 3, 2007 | 04:25 PM
  #26
danziger's Avatar
I agree. The ringlands and rod bolts are the weak links in the LS1. That makes over-revving and detonation your worst enemies...not absolute HP.
Old Mar 4, 2007 | 12:02 PM
  #27
YBNORMEL's Avatar
fast intake
90mm throttle body
new 1.7 rockers
yank 3200 stall
and dyno tune
That H/C package sounds very nice, you might what to go with 4.10's instead of the 3.73's.
Just a thought though, how many miles are on your bottom end. You might consider a ls2 short block with the new L92 heads and l76 intake. This combo seems is getting over 500 hp to the rear wheels and might be cheeper in the long run if you have to go in and rebuild your short block in a year or two.
Old Mar 4, 2007 | 07:25 PM
  #28
burn's Avatar
its right around 50,000
Old Mar 4, 2007 | 10:26 PM
  #29
Kraest's Avatar
Retired
fast intake
90mm throttle body
yank 4000 stall
and dyno tune
Edited your list.
Old Mar 4, 2007 | 10:51 PM
  #30
myslowcamaro's Avatar
Originally Posted by Kraest
Edited your list.
yep. some people on here have gotten the new roller rockers but stock seems to hold up just nice. i know teke got the harland sharp ones, and i mean no offense to him in saying this but personally i think its a waste of money without a seriously built up engine to put them on. sure you get a few hp, but for the price, other mods like a tc, ls6 intake, or any combo of smaller bolt ons can be purchased if needed for the same price.
