how much power
Old Feb 7, 2007 | 07:46 PM
burn's Avatar
how much power
i am a new owner of a 02 z/28 auto and wondering how much rwhp the stock bottom end can take before you need to worry this will be a daily driver and want to do a head and cam i would like to get around 400 to 450 at the wheels will the bottom end hold what would be a good combo for head and cam i already have underdrive pulley and lid
Old Feb 7, 2007 | 08:45 PM
lastZ's Avatar
well if its an 02...you probobly have the ls6 block.....and it will handle that much power easy....as far as the cam and heads....ill let someone else chime in
Old Feb 7, 2007 | 10:29 PM
sandman63's Avatar
Only 25% of F-bodies in 2002 came with a LS6 block.
Old Feb 8, 2007 | 06:25 AM
teke184's Avatar
one word...punctuation...
450rwhp is very doable and the bottom end will take it with minimal concern.
an auto is gonna be harder to get to your goals, but it can be done
400rwhp...any of the mid 23x cams and boltons with a dyno tune will meet your goal. something like the FM14 from futral, or the TSP Torquer or MS3/4
450rwhp will require heads and probably a new FAST intake.
don't forget things like torque converter and rear end when you start making that kind of power.
do some reading on the last 15 pages of the forum...most of what you asked is covered weekly
Old Feb 8, 2007 | 01:33 PM
Ripper415's Avatar
i was under the impression that all the 01 & 02 cars came with the ls6?
Old Feb 8, 2007 | 02:42 PM
sandman63's Avatar
Yeah all the 2001 an 2002 F-bodies came with the LS6 intake, not the block. In 2001 15% of the cars came with the LS6 block an stated in my earlier post 25 % in 2002.
Old Feb 8, 2007 | 03:57 PM
Kraest's Avatar
Retired
I'm over 500 rwhp on the stock bottom end through the automatic, which is more like 530 rwhp on a 6-speed.
Old Feb 8, 2007 | 05:02 PM
David @ Thunder's Avatar
For a heads/cam streetable auto combination 400-410 rwhp is pretty acheivable. When you start getting into more aggressive camshafts to make higher hp, depending on the car owner, it might become less streetable and then its more difficult to get tuned "properly". Everybody wants a big hp dyno number, but forgets about the rest of the drivetrain or what it takes to make the car perform with the new power. Maybe your looking for certain times as well?? It doesn't take much power to get these cars to perform, just the right combo of drivetrain and power.
p.s. The stock bottom end will be fine for any street head/cam combinations.
Old Feb 8, 2007 | 06:57 PM
burn's Avatar
I know i am not an english major so sorry.
i do plan on putting in a 3200 yank
thinking either 3.42 or 3.73 gear not sure which.
thanks for the help.
how do i tell if i have a ls6 block?
i know i said every day driver but it will not be every day mostly weekends.
and maybe one or two days to work but i have another crapy car for work
but if the p.o.s. doesnt start i dont want to worry taking the good car and having the feather the gas to keep it running
Old Feb 8, 2007 | 10:26 PM
Bayer-Z28's Avatar
Apparently there have always been two version of the LS1: One built in Montupet, and one built in Nemak, Mexico. They use two different methods in creating the block, and apparently the Nemak block is a stronger, more performance oriented block. (The material properties were about 10% higher/stronger. Nemak uses a low-pressure precision fan process, more high performance oriented.). When the Z06 Corvette came out, GM decided to use the Nemak plant to build the LS6 block, since they built stronger blocks. So Nemak built LS6's, while Montupet built LS1's. Since there were so many LS6 blocks made, several made it into F-bodies. Numbers from GM are that about 10-15% of 2001 cars had LS6 blocks, and 25% of 2002 cars did. To confirm if your 2001-2002 F-body has an LS6 block, grab a mirror and a flashlight. Open the hood and head over to the driver's side to try and see the back of the left-hand deck, above the transmission flange. A cast-in #12561168 denotes the LS6 block. And if you aren't able to see the number, you may be able to tell by the block's luster-the Montupet plant cast a shinier block, the Nemak plant made the duller block. The Z06 block (LS6 block) is not only much stronger, it also has 87% better ventilation between bays, which equates to less pumping losses at high RPM's
YEah.. Not all 01's and 02's came w/ the LS6 block.. a fraction of them, but I still like the #....
The bottom end of the LS* block is a 6 bolt main and can handle a LOT of power. I've heard people running about 800 hp on a stock block. On an FI block, H/C w/ stock intake and 5-8psi boost is the breaking point for most. I would say heads (205cc) and an average mild cam (228/ .581) cam w/ a 125 shot of N2O would be about borderline on a stock bottom end LS1/6.
Old Feb 9, 2007 | 09:25 AM
SSpdDmon's Avatar
Aside from heads, cam and valvetrain...I've heard the stock internals can handle about 550hp at the crank. Much more than that and the ringlands might start to go. The crank itself is pretty strong...but, the supporting hardware like the rod bolts can let go from high rpm use. In the end, the thing to remember is there's a right way and a wrong way to make power. Pick two of the three:
1) Cheap
2) Reliable
3) Powerful
Old Feb 9, 2007 | 06:49 PM
AL SS590 M6's Avatar
Moderator
1) Cheap
2) Reliable
3) Powerful
I personally think that number is a little low. I have a friend with a turbo on a stock bottom end with 6.0l heads and it's been putting out well over 500 rwhp for several years. This is a 3800 pound street car with everything working that runs low 11s at 130 mph on drag radials.
Old Feb 9, 2007 | 06:53 PM
burn's Avatar
what do you think of this combo
trick flow heads 215cc
trick flow stage 3 cam lsa 112 228 230 @.5 .585 .585
fast intake
90mm throttle body
new 1.7 rockers
jet hot long tube headers
yank 3200 stall
motive 3.73 gears with new locker
and dyno tune
Old Feb 9, 2007 | 07:07 PM
myslowcamaro's Avatar
sounds ok, someone with better cam knowledge can tell you if 90/90 is overkill for you. you migh tbe able to get away with ls6 intake. i wouldnt waste the money on new rockers just yet. put that money elsewhere. do your research on the torque convertors too. if you plan on running n20, some tc's say this part "acts like an anti-balloon plate" while others actually have the ab plate
Old Feb 9, 2007 | 07:11 PM
burn's Avatar
I dont want to run turbo supercharger and n20
i dont understand them enough to run them and remember my dad says keep it simple stupid
I think that h/c and tune with some other parts would be safer with me
