How much is a new Instrument Cluster?
Old Dec 21, 2002 | 10:10 PM
RobZ's Avatar
Question How much is a new Instrument Cluster?
The instrument cluster on a ls1 car that I bought is bad..How much are these instrument clusters and were can I find one?Any help is Appreciated..
Old Dec 22, 2002 | 04:29 PM
01SunsetOrangeSS's Avatar
There is only one place to get a cluster from, the dealer! Cost is about $300, you can put it in yourself but you will have to take it back to the dealer to have them sinc it with your ECU. If you get one from a junk yard, it may or may not work and you will still have to take it to the dealer. Choice is yours, I had to buy a new cluster and wholesale it cost me $245. Good luck.
Old Dec 22, 2002 | 08:31 PM
DARK AGE 53's Avatar
Re: How much is a new Instrument Cluster?
Bad meaning what?
Al
Old Dec 23, 2002 | 01:25 AM
RobZ's Avatar
Well my buddy said there was a short or something inside.Also the back light bulbs were burned out.
Old Dec 23, 2002 | 01:40 AM
RobZ's Avatar
Does the speed cluster have to be from the Same year?
Old Dec 23, 2002 | 01:42 AM
stik6shift98's Avatar
i saw one on ebay a couple weeks back for like 90 bucks
the bad thing is it wont show your real miles
itll show whatverr the one ur getting has on it
ya the clusters are the same form 97-02 i think
Old Dec 23, 2002 | 02:53 AM
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=6773&item=18749892 64
it shows around 4 k miles auction at 40 bucks reserve not met
im guessing it will sell for 100
Old Dec 23, 2002 | 03:20 AM
RobZ's Avatar
Darn....Too bad its for a Camaro.
Old Dec 23, 2002 | 08:35 AM
oh what do u need it for........i assumed u had a maro
Old Dec 23, 2002 | 03:30 PM
NEWBIE T/A's Avatar
Lightbulb You can buy a re-man one from the local A/C Delco authorized rebuilder ...
But I have no idea what it would run outright.
In Houston, mine is a company called Zener - I had problems with tyhe "fixed" one installed by the dealer.
The dealer did not care to help me, so I went direct - Zener tested my old one, agreed that the gauge readinsg were off, and gave me another reman that was so clean it looked like brand new !!
I did , however, have to have the PCM reprogrammed to recognize the new cluster as my Air Bag warning light would not go off.
It's worth a shot - Good Luck !
Britt
Old Dec 23, 2002 | 04:02 PM
Rob, if the cluster goes crazy and the trip resets after you start the car there's a TSB about this problem, I don't know about the lights but if you're just having problem with the trip resetting it's self I'd leave it alone unless it can be replaced under the TSB. Another thing that can cause the cluster to have problems is a weak battery.
Old Dec 25, 2002 | 02:41 AM
RobZ's Avatar
Dark,What is the TSB thing you are talking about?Also my Mileage screen doesn't come up.I can live with out that or even if I were to pick up a used one with the incorrect mileage would be okay
Old Dec 25, 2002 | 05:26 AM
RobZ, Technical Service Bulletin, these are issued to the dealers when the manufacture finds there may be a problem with a part. It's not a recall so the company doesn't need to let you know of the problem, in my opinion there's been enough of these problems that it should be a recall.
Old Dec 26, 2002 | 12:53 AM
what car is this from?????
not camaro......
ta....
vette.....
IndyZman
Oct 22, 2015 02:17 PM
4586
Aug 24, 2015 11:04 PM
4586
Aug 13, 2015 10:11 PM
nosliw
Apr 27, 2015 04:01 PM
Chrisdude
Aug 31, 2002 12:08 AM
