How much do LS6 intakes usually go for?
Old Jun 30, 2003 | 01:49 PM
Mike94ZLT1's Avatar
Just like the topic states, I was thinking about swapping my intake for the LS6 style. What do they usually go for? Thanks guys!
Old Jun 30, 2003 | 01:56 PM
Ferocity02's Avatar
Usually around $465 new. You can get a very good used one for around $300 maybe
Old Jun 30, 2003 | 02:10 PM
SSpdDmon's Avatar
The other option for a new intake manifold would be to get the part number from a local dealer and order it from www.gmpartsdirect.com . The part number I have is for a package that includes the manifold, all gaskets/seals and a MAP sensor I believe. It goes for $350.
part # 88894339
This is the same manifold used on the Z06 Vette and is different from the SLP version because it doesn't include provisions for the EGR system. So, you would have to remove your EGR assembly and have someone reset the code with LS1 edit. It might be worth it to get everything for $115 less.
Old Jun 30, 2003 | 02:38 PM
SSCamaro99_3's Avatar
$300+
Old Jul 2, 2003 | 10:12 PM
Demon SS's Avatar
from GM parts direct it is $421.78 with shipping and does not include the new style coolant pipe or plugs that are needed for the 2000 and older f-bodies. GM parts direct looks good on the surface only, most of the time. and if you have a problem with your item are basically SOL.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
R@mpage
Apr 20, 2015 10:02 AM
99TransAmWS6
Mar 22, 2015 11:00 PM
birdblack
Dec 30, 2014 06:59 PM
hotrodyou1
Dec 20, 2014 10:05 PM
