How many O2 sensors on an LS1?
Old Jun 20, 2002 | 08:38 AM
roofo's Avatar
Question How many O2 sensors on an LS1?
How many O2 sensors on an LS1?My friend has a 99 Z.He had long tubes put on(hookers).The check engine light came on(he got rid of the cats)So he needs O2 simms right.Does he need two?
Old Jun 20, 2002 | 09:03 AM
V6toZ28's Avatar
Post
4 ... one in front of each CAT and one behind each CAT. You'll need sims to replace the rear O2s.
Good Luck
'01 Mystic Teal Z28
A4/3.23/Leather/T-Tops
Mods List Here
12.46/108.87/1.75 60'
319 rwhp/349 rwtq
www.MysticZ28.com
NorCal LS1/LT1
"To play it safe is not to play"
Old Jun 20, 2002 | 11:34 AM
asianice25's Avatar
Cool
Just to clear that explaination up a bit, theres four o2 sensors on the car. one before the cat and one after on each side. The front sensor do the real lean/rich work while the back ones pretty much let the computer know that the cats are doing their job. you need two o2 sims to replace the back two sensors. they are always around 100 bucks, so not too bad.
Scott Parkinson
2001 Sunset Orange Z-28
SLP Loud Mouth, K&N, Mass Air, 160 Thermistat, Power Programmer, All aftermarket suspension/braces, 8.5mm Plug Wires, 125 hp Shot. Runnin low 12's all day.
captcorvette
Mar 7, 2015 12:37 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
HCz28
Jan 11, 2015 11:17 AM
