how to gut the cats?
Old Oct 29, 2003 | 08:11 PM
ponystomper's Avatar
what will I have to know to do this? I know I will need some 02simms. I am getting a code for" catylist efficency below threshold" so I figured this would fix the problem. am I going in the right path?
thanks,
mike
Old Oct 29, 2003 | 08:25 PM
Knowklew's Avatar
If you are going to run O2 simms then why dont you just eliminate the cats all together with an offroad y pipe
Old Oct 29, 2003 | 08:28 PM
Greed4Speed's Avatar
The cats are warranted for 8 years and 80k miles. If you are w/in the limit get them fixed. Otherwise be a responsible car owner and run some highflow cats. Its a measley 2 hp difference between them and open pipes.
Old Oct 29, 2003 | 08:45 PM
I do want to eliminate the cats. where do I find an oryp that bolts to stock manifolds and the loudmouth? I did not think the was a y-pipe that bolted to stock manifolds and took the place of the cats. I dont care about hp gains just want this problem fixed. so I figured gut the cats or find pipes to put in their place. opinons?
Old Oct 29, 2003 | 09:00 PM
Knowklew's Avatar
http://www.lmperformance.com/564/1.html
Or im sure an exhaust shop could fab one up for you that would work.
Old Oct 29, 2003 | 09:55 PM
the mac oryp says its for 98-99. but will it still bolt up on a 2000?
Old Oct 29, 2003 | 10:02 PM
Knowklew's Avatar
Call and ask or look around for one for a 2000
Old Oct 29, 2003 | 10:19 PM
thanks for your help
Old Oct 30, 2003 | 11:50 AM
Here is a bit of info to chew on about running w/out cats. I was rummaging through some old mags and found the September 2000 issue of Car Craft.
They did a test to see if cats robbed power. Test was on a supercharged 305 5spd on a chassis dyno so all the #'s are RWHP.
w/out cats Max hp: 321.2 Max tq: 356.9
w/cats Max hp: 319.6 Max tq: 364.3 the pull w/the cats netted more torque across the entire RPM range.
This will also help keep the EPA Environazis out of your area too.
Old Oct 30, 2003 | 12:01 PM
6spdpewterZ's Avatar
Take them out......
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
Sep 11, 2015 09:44 AM
