How does traction control work????
Old Aug 29, 2003 | 03:19 PM
My90Iroc's Avatar
I just bought and LS1 rear end for my car and realized it has TCS on it. I need to figure out how to make this work in my car, with or without TCS being functional. Any ideas on how I can make this work without the TCS? Also, is the TCS controlled by the computer or just by a sensor on the brake like ABS (which in theory I could just put power to the TCS sensors and have TCS on a third gen)? Thanks.
Brian
Old Aug 29, 2003 | 04:35 PM
Ken S's Avatar
they have two reluctor rings out back, one for each wheel - so it can sens whats going on each wheel independently.... This setup also means they have a 4 channel ABS system.. A non traction controlled ABS f-bod just has 1 reluctor ring (3 channel)
Don't quote me on this, but I believe TC cars also have more brake lines coming out because they individually control the back brakes..
Don't forget a line to give that pushback on the gas pedal too..
Its all handled by some computer.. seperate or not, i dunno..
I'm assume you just have to get an ABS ring off a non TC car and use that...
Old Aug 29, 2003 | 07:04 PM
KwikistZ's Avatar
Well, on my 96 Z it just had a little electric motor that pulled the pedal back and closed the TB a bit. Maybe that also? I dno....
Old Aug 30, 2003 | 07:49 PM
99blackSS's Avatar
Yeah, ASR (what they call the traction control on LS1s) kicks up the gas pedal.
DirtyDaveW
Dec 1, 2016 05:37 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
