How do you make the temp gauge functional on 99+ cars.
Old Jan 26, 2005 | 10:54 AM
AronZ28's Avatar
I have a 1999 Z28. The temp gauge is like an idiot light, it reads cold, then moves up to normal and won't move unless the engine tells it there is a catastrophe. I have heard that 1998 LS1's had a functional temp gauge.
How do I convert the gauge to be functional? Would it require the PCM to be reprogrammed? Would I change the coolant temperature sensor? Or would I have to change the gauge itself?
Old Jan 26, 2005 | 11:07 AM
stone4779's Avatar
Re: How do you make the temp gauge functional on 99+ cars.
I'd like to know as well....
I'd be willing to do all of the above except change the pcm to get this thing usable...
I'd just like to be able to know when its at its coolest. Without having an extra gauge in a pod or something lol
Old Jan 26, 2005 | 11:37 AM
MasterEvilAce's Avatar
Ever thought that maybe the LS1 is so awesomely designed that it stays very level as far as temperature specs go?
Old Jan 26, 2005 | 11:56 AM
stone4779's Avatar
naw....I've driven a '98 and the gauge definately moves around...
Old Jan 26, 2005 | 02:05 PM
bunker's Avatar
I bet you anything you just have to change the temp sensor, its like the 95 Impala SS had an oil pressure guage that was like an idiot light but the 9c1 cop cars did not, the difference is only the sending unit, so I bet its the same.
Old Jan 26, 2005 | 02:52 PM
shouldaboughtthez's Avatar
so get a sending unit from like a 98 and see what happens?
Old Jan 26, 2005 | 05:14 PM
SFB767's Avatar
I've heard that the reason the '99+ LS1s have the dummy gauge was because the '98 owners complained that it fluctuated WAY too much.
Old Jan 26, 2005 | 09:12 PM
L8ER's Avatar
Cool Re: How do you make the temp gauge functional on 99+ cars.
I took my car into the shop because it smelled hot, they told me the same thing. There was so many people getting excited because it moved so much. My temp said 210 but I was at 216. I also would like to know how to get it to read the correct temp, nice to know exactly what you are running.
Old Jan 27, 2005 | 12:31 AM
mebanditws6's Avatar
You'd have to program the PCM and get a sensor for a 98 car. The 98's have a dual circuit sensor that sends to the PCM but another one that sends directly to the guage. The later ones only have the circuit that sends to the PCM where it is basically turned into a dummy guage. I think with a PCM reprogram, you may be able to get the PCM to ignore the sensor readings and pass it directly to the guage.
Jason
Old Jan 27, 2005 | 08:04 AM
AronZ28's Avatar
Doesn't the PCM need to know what temp the coolant is at?
Old Jan 27, 2005 | 01:12 PM
Yeah, but I would think you could program it so that it won't desensitize the guage like it does now.
Jason
Old Jan 27, 2005 | 01:35 PM
Mike94ZLT1's Avatar
I left it alone, and installed an autometer sender in an auxilary hole above the starter, and added a water temp gauge to the collection on my a-pillar.
Old Jan 28, 2005 | 04:58 PM
And there is your second option.
Old Jan 29, 2005 | 04:13 AM
94ZRiCeKiLr's Avatar
this would have been my suggestion...
DirtyDaveW
Dec 1, 2016 05:37 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ro2207
Dec 4, 2014 06:18 PM
