How difficult is it to swap heads ?
Old Feb 19, 2005 | 12:45 PM
BadgeZ28's Avatar
How hard is it to remove original heads and replace them in car? The car is a 01 Z-28. I have been watching the engine removal and build up on horsepower TV. Last week, they drilled two 1/2" holes in each lifter box to help oil return faster to the crankcase. Anyone recommend this mod while the head are off? Thanks
Old Feb 20, 2005 | 01:04 PM
mrr23's Avatar
Re: How difficult is it to swap heads ?
took me and a friend about 10 hours to do the swap. here's pics http://www.stealthram.com/1999pontiacformula.html click VHP head install.
Old Feb 20, 2005 | 05:04 PM
GPZ28's Avatar
Depends on your skills... If you need to ask................well
be carefull and make sure everything is clean clean clean
cleanliness is next to godliness..................
Old Feb 20, 2005 | 05:58 PM
BadgeZ28's Avatar
I have worked on motors before, but never set back in the body like a LS1 in a forth generation F-Body. I was concerned about getting at rear fasteners and torquing the head bolts at the rear.
Old Feb 20, 2005 | 06:11 PM
GPZ28's Avatar
I hear that..........you need to be creative.....
no prob if you know what your doing ......................same only different
Old Feb 20, 2005 | 06:25 PM
mrr23's Avatar
it isn't near as hard as it looks. just having to pull the breaker bar from across the car when tightening down the last 90* turn takes a little effort. the only real hard part was that damn bolt behind and under the power steering unit. you either pull the pulley off or, you take all three bolts out slowly . and pull the power steering unit with it to get the bolts completely out.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
