Horsepower
Old Feb 6, 2004 | 11:00 PM
seabass2004's Avatar
Horsepower
Well the time has finally come i am finally swaping my v6 for an LS1 i found an 01 LS1 at a hell of a deal and was curious to how much hp these put out stock. any help on this would be great.
Old Feb 6, 2004 | 11:18 PM
Antz97ZNJ's Avatar
Over 300 rwhp...
Old Feb 7, 2004 | 01:15 AM
HoustonZ's Avatar
Drive a 1985 Honda accord for a month, then drive your 3.8 V6. That's the difference you will feel. I have owned both 3800 V6 and LS1 (current Z), and the difference is best described as "Holy Sh*t". Don't want to get too technical there on you bud. You'll see.
Old Feb 7, 2004 | 01:24 AM
warwickbass's Avatar
HAhaha. Night and day describes it best?
Old Feb 7, 2004 | 01:49 AM
HoustonZ's Avatar
forgot to add...
I saw some stock 2000 Z28 dyno results, as well as results of that same car after an aftermarket lid installation. They used the highest of 3 runs for both results.
Stock= 317 RWHP
Lid= 328 RWHP
That's pretty damn good considering they are rated 305HP, which I thought was at the crank. BONUS!
Old Feb 7, 2004 | 09:02 AM
USHotRod's Avatar
Originally posted by HoustonZ
forgot to add...
Stock= 317 RWHP
Lid= 328 RWHP
What lid gave you that?
Old Feb 7, 2004 | 09:30 AM
hurricaine418's Avatar
horsepower numbers
not to switch gears here, but curious. i see the above numbers for rwhp, but whats a stock ls1 or w/ lid hp at the crank? how much lower than the 03 cobra? cobra 390 rwhp or hp?
Old Feb 7, 2004 | 09:36 AM
USHotRod's Avatar
Re: horsepower numbers
I believe average hp numbers are 315 rwhp, slightly lower for A4's. Given an 8% drivestrain loss (being generous) that would give you around 340 hp at the crank. If we knew how bad the actual drivetrain loss was, we could get a more accurate estimate.
Old Feb 7, 2004 | 09:53 AM
darrens99formul's Avatar
Don't let these guys convince you that all LS1's dyno 300-320 RWHP stock. Some do but others dyno 280-300 RWHP. I have even heard of a few "slugs" that dynoed 275 RWHP. Then again I also heard of M6 "freaks" that dyno 320 RWHP.
01 & 02's will usually dyno in the 300-310 Rwhp range while 98-00's tend to dyno 280-295ish. Auto's also lose more HP in the drivetrain so some 01 & 02 autos might dyno just under 300. But once the modding starts they can do very well. 350-370 RWHP with bolt-ons and 400+ with just a cam!
Good luck with your new ride and welcome to the dark side
Old Feb 7, 2004 | 09:55 AM
USHotRod's Avatar
Thats true. I did forget about the 98 + 99's dynoing a little lower. My bad.
Old Feb 7, 2004 | 10:52 AM
Capn Pete's Avatar
The factory rating (which is completely false ) is 305 HP for '98 - '00, and 310 HP for '01 - '02 Z28's and Trans-Ams. However, if you got the SS or the WS6, then they came with a different catback exhaust, as well as "ram air", so GM rated them higher, at 335 or 345 HP I think. BUT, I think most guys would agree that the engine in ALL LS1 cars is still capable of closer to 345 - 350 HP, same as the LS1 Corvettes, but GM just underrates the F-bodies. If the engine didn't make 350 HP, then how would it be possible for guys to dyno over 300 RWHP?!
Old Feb 7, 2004 | 11:05 AM
USHotRod's Avatar
I believe the 98-00 Z28's and Formulas were rated at 305. The SS and Trans Am had a rating of 320. All ratings saw a 5hp increase in 01-02. I think the Firehawk had a rating of 345 or so.
Old Feb 7, 2004 | 12:02 PM
Buffdaddy's Avatar
Around 320hp. I had a v6 and the day I got my SS, I thought why did I wait this long to get the v8. You will love it!!!
Old Feb 7, 2004 | 12:13 PM
V6toZ28's Avatar
Don't believe internet dyno numbers ... people fudge 'em, trick 'em and dyno shops recalibrate so their numbers will compete ...
I dynod my '01 A4 at 278 rwhp stock ... never got more than 335 rwhp with all the bolt on's and 403 rwhp H/C ... and I consistantly out run other cars that have the "big" dyno numbers ...
Old Feb 7, 2004 | 03:42 PM
Capn Pete's Avatar
Whether it's true or not, I'm sure some may argue that an M6 in your car would put down more to the wheels............it probably would, but by how much is the question?! Probably 5 - 10 rwhp more.
I agree that there probably are some "tuned" dyno numbers out there, but I don't discredit all of it, because I'm also not convinced there is a 40 HP difference between the Corvette LS1 and the F-body LS1. So, believing as I do, that the LS1 in the F-body puts out close to 350 HP (crank) then I think it's fair to expect 300 - 315 rwhp based on 10 - 15% drivetrain loss (or 280 rwhp based on 20% loss, which may be the case for your car? ).
It's not uncommon to have 2 identical cars, motors, transmissions, and for one of them to simply out-perform the other one. That's why there is such a range in #'s for LS1 cars, no matter whether they're 98's or 02's. Another point is that some have run into the 12's (12.9's) bone-stock, while some couldn't even hit 13's, such as my car, which only ran 14.1 @ 103 on its first trip to the track.
