Hooker LT Headers
Old Dec 12, 2002 | 03:22 PM
XKnightRider's Avatar
Hooker LT Headers
So I have a set of Hooker LT's, with the y-pipe, clamps and 02 sims. What else do I need?
Header bolts? Can you reuse the stock ones or not?
Gaskets, I've heard the a new set of stock ones is a good idea.
Also, the Headers have the EGR tube on them but I have an '02, does anyone sell a blockoff plate for this?
Thanks...
Old Dec 12, 2002 | 04:28 PM
PhantomTA's Avatar
Moderator
02 extensions as well..
But..
The headers come with them, bolts and gaskets..
you need nothing else.
PaceParts has block offs. hell i have extras but you dont live by me.
Old Dec 12, 2002 | 06:57 PM
I bought them used, so I have no bolts or gaskets, but I have the clamps, O2 sims, and O2 extensions.
Can stock bolts be used or should I get something like Stage8's.
Old Dec 12, 2002 | 07:17 PM
MRZ28HO's Avatar
Exclamation
I reused my OEM bolts and gaskets. But yes, if you can/want, get new gaskets. Also, you will either need to buy '98-'99 air tubes or modify your air-tubes (by rotating the base approximately 90 degrees). When you install the headers, be sure the car is raised more than 24" (or on a lift). Also you'll need to remove the steering shaft that connects from your steering whel (outside) to the rack-and-pinion. And finally, the oil diverter valve located directly above the oil filter. A little bit of oil will come out. Any other questions, please post and we will be happy to help.
Old Dec 12, 2002 | 07:26 PM
phil1001's Avatar
HAIL PHANTOM TA, on the sig, if i hear nos one more time, it is nitrous, damn fast and the furious
Old Dec 14, 2002 | 01:12 PM
Any idea how much 98-99 AIR tubes cost?
Hopefully I can stop by the dealship today...but if anyone knows....
13qtr
Jul 19, 2015 05:30 PM
Strick
Jul 14, 2015 07:28 AM
mrwz28
Jul 8, 2015 09:11 PM
