Holy ****!!!
Old Mar 7, 2004 | 12:57 PM
Omega9's Avatar
Thumbs up Holy ****!!!
http://www.ls1tech.com/forums/showthread.php?t=138439
I guess Spring Break = cam time
Old Mar 7, 2004 | 03:08 PM
Amit's Avatar
Old Mar 7, 2004 | 03:51 PM
the pool boy's Avatar
that is ungodly
Old Mar 7, 2004 | 05:27 PM
Mikael's Avatar
Yeah, but if you put a big cam in an LT1-oh wait, no it won't.
Old Mar 7, 2004 | 05:48 PM
Capn Pete's Avatar
Just so there's no mistake here, did he just dyno 451 HP / 408 TQ with a camshaft alone?!?!?!?
Huh, well I guess it's time to start cam shopping!!!
Old Mar 7, 2004 | 06:42 PM
Omega9's Avatar
Yes, yes it is. This week I'm not going with that monster though, I want around 390rwhp.
Old Mar 7, 2004 | 08:14 PM
Poltergeist's Avatar
Read his sig. It says GTP stage 2 heads. So not just a cam, but still very impressive numbers. If you go to HERE you can see everything he has done with his motor.
Old Mar 7, 2004 | 09:02 PM
Omega9's Avatar
Even though he has the stage 2 heads, the experiment was done with stock heads. Check out thunderracing.com too because they dynoed the same with stock heads. Goodbye 03-04 cobra. We will miss thee.
Old Mar 7, 2004 | 09:23 PM
danziger's Avatar
Exclamation
Hope that car isn't a daily driver!
Old Mar 7, 2004 | 10:35 PM
Capn Pete's Avatar
Um, Poltergeist & Omega9, you guys got conflicting posts! One says with STOCK heads, one says with STAGE II .
I read through that thread again, and I do believe it's 451 HP / 408 TQ with STOCK heads! I also clicked into the thread where he dyno'd the first version of that cam and got 440 HP / 405 TQ . The guy said that these cams are being specifically designed to run with stock heads (but computer tuning IS necessary).
So, 440 - 450 HP, naturally aspirated, on STOCK heads!?!?!?
.........SIGN ME UP!!!
Old Mar 7, 2004 | 11:45 PM
tailwindxr7's Avatar
That cam is way too radical for me.
I'd much rather have 360-380 RWHP that's easily-driven, reliable, and has decent gas mileage than 440 RWHP with a choppy-*** idle, horrible mileage, and a lot more wear and tear. Not mentioning the T-rex also requires 4.10s with a manual or a huge converter with an auto...I'd only consider it for a track only car, not something driven on the street.
Old Mar 8, 2004 | 12:00 AM
Yeah I went through both threads (all the way this time) and it was on stock heads. The cam is 242/248 .608/.612 110lsa +2. M6s need 4.10s and an A4 needs 4000+ stall. Also you need a few other things for it, valve springs etc. Still like I said before very impressive numbers.
Old Mar 8, 2004 | 12:27 AM
Klypto's Avatar
what kinda of gas mileage for a cam like that?
Old Mar 8, 2004 | 06:02 AM
thezisking's Avatar
My guess is somewhere around 2 or 3 gallons per mile
Old Mar 8, 2004 | 09:09 AM
Camaro_Guru16NY's Avatar
Thats some awesome numbers !!!
-JOhn
Boss002
Jul 9, 2015 03:33 PM
Doug Harden
9
Dec 5, 2003 06:54 PM
Umbrae
Sep 29, 2003 06:38 PM
camaro322hp
Sep 6, 2003 11:17 PM
91Bird305
Aug 21, 2002 04:38 PM
