Hints, tips, suggestions...
Old Jun 12, 2005 | 06:49 PM
35thZ282002's Avatar
Ok, I'm uninstalling my stock exhaust manifolds (finally got some LTs). The passenger is a friggin' PITA! Any suggestions on how to reach the studs near the dipstick and the far back one? These are really the only 2 that are a problem. Any tips or criticisms are appreciated...
Old Jun 13, 2005 | 12:45 AM
hates rice 24's Avatar
Re: Hints, tips, suggestions...
i just installed mine last weekend. take the dipstick out, there is one 15mm (i believe) bolt holding it in on a bracket, and it just pulls out...that will give you access to those two bolts. The one in the back is the fun one. Jack up the car and go from underneath. After you take the cats off it gives you a lot of room. I have skinny arms so it wasn't too bad. Do a search, there are a few install guides online that may help. Hope this helps
Old Jun 13, 2005 | 06:23 AM
teke184's Avatar
i was able to do all my bolts from the top.
used a combo of a 3/8" drive and 1/4" drive socket.
make sure you pull the coil packs...it gives you tons of extra room.
look into my install guide, may find some helpful info
Old Jun 13, 2005 | 05:03 PM
Ok, thanks guys. I'm not a mechanic so these simple questions are rocket science to me. Is removing the coil packs a huge project, or is that a simple thing?
Old Jun 13, 2005 | 10:14 PM
Rice Killer87's Avatar
I think its 2 connectors on each side, and like 6 bolts for each side and they come right off.
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
autoxr166
Sep 25, 2015 04:21 PM
Godamnilovemy79
Sep 3, 2015 03:40 PM
colts0455
Sep 2, 2015 12:41 PM
