High idle after cars warm/driving
Old Aug 22, 2007 | 06:20 PM
krazykorean35's Avatar
my idle is set at 1100 but recently when i pull up to a light/stop sign and put the car in neutral my idle rises to about 13-1400...stays there for a few seconds then dies down. checked my lid/cleaned the maf and tb. still have the issue. any ideas?
Old Aug 22, 2007 | 07:32 PM
Bayer-Z28's Avatar
if you're hard on the brakes, you're lowering the vacuum in the intake, and therefore raising the idle... (going from vacuum to atmospheric pressure)
Odd thing.. I was JUST thinking of this earlier. "I'm surprised I haven't heard this question on the boards yet.. "
Old Aug 22, 2007 | 09:22 PM
Kraest's Avatar
Retired
LS1s act funny like that when you do cam swaps on them if they aren't tuned 100% (and by 100%, I'm talking about being tuned for hours)
It's nothing to worry about. Try swapping with someone's else's MAF if you're honestly concerned.
Mike
Old Aug 22, 2007 | 10:32 PM
thanx 4 the replys! just tryin to work out the small things...its easier to diagnose when theres a huge grinding or thumping sound haha
Old Aug 23, 2007 | 01:14 AM
mmannSS's Avatar
Another idea... the throttle position sensor. My TPS recently took a dump. The first sign was that the engine would idle fast after it had warmed up. Long story short the Service Engine Soon light came on a few months after I first noticed the high idle. I pulled the code and it came up as a throttle position sensor error. Anway, I replaced the TPS and all is back to normal. Not sure in you case sense you have quite a few engine mods. Just an idea.
Old Aug 23, 2007 | 05:53 PM
no SES light yet but that would make alota sense. wouldnt be the first sensor to have gone out recently...thanx!
Old Aug 23, 2007 | 09:03 PM
Kraest's Avatar
Retired
Not going to be the TPS.
What you're talking about is surging/searching due to a cam swap when coming to a stop. Lots of cam-swapped cars do this without perfect tuning.
Old Aug 23, 2007 | 09:26 PM
hmm so get a better tune! gotta get the speedo recallibrated for the 4.11s...might as well drop it off for a couple more hrs to get re tuned
Old Aug 23, 2007 | 09:31 PM
Kraest's Avatar
Retired
Tell them to check the IAC values and if they can't get it right with that, they may have to drill the throttle body.... I can't see them not getting it right with only a LS1 Hot Cam, though..
Noenav
Mar 1, 2019 07:38 AM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
Lions3
Apr 11, 2003 10:55 AM
