high flow bellows
Old Nov 14, 2002 | 06:42 PM
  #16
Camaro ChriSS's Avatar
Originally posted by GregWS6&Z28
Many Satisfied customers with the Redhawk. How did you see the stress it produced under Wide open throttle? ???????
I assume when everyone is saying Redhawk mod they are referring to the 3x4 Fernco mod - same thing (not the silicon hose).
You can simply rev the engine while in park (though this isn't something to make a habit of, as it isn't good for the engine) and you'll see the engine twist (naturally...). The engine is designed to twist, but the airlid is not. That's why that accordian bellows is in there. The Fernco fiiting WILL flex somewhat, but not very much. Some guys have run the hose on their car for years without a problem (knowledgable people too, like Raughammer, Redhawk, etc...), but others have cracked the tabs on their airlids, destroying the seal. Have a look as the aftermarket lids and you'll see how fragile they are around the two little tabs on the back... although they are great for smoothing out airflow, they are not as strong as the factory unit lid. Of Course, if you're not putting pressure on the lid, it doesn't matter if it's not very strong.
Try a search on LS1.com or LS1tech.com and you'll see more than a few complaints over the years with the Fernco mod.
Old Nov 14, 2002 | 07:05 PM
  #17
GOT2HAVLS1's Avatar
Originally posted by Dark Angel
Get a Fernco 3" x 3" flexible plumbing coupler, Part #P1056-33. $4.98 from Home Depot. Goes on the MAF easily and with a little stretching goes on the TB. Cheap Mod if this is what you want.
the Fernco takes a little bit of heat before it will stretch, but once its on....its on. And like Dark Angel said. Its like 4 bucks. Once again, just as I'm gonna do w/ the .99 cent resistor for the skip shift. I'm gonna start a business!!!
Old May 31, 2003 | 01:43 PM
  #18
z28200235's Avatar
Hey yu guys are lucky you live close to a Homedepot
nearst home depot to me is like 28miles.. I bought my bellow at Ace hardware for $5.
Old May 31, 2003 | 01:48 PM
  #19
z28200235's Avatar
Hey guys Has anyone dynoed there car stock and with mods. I have the airlid mod, bellow, Flowmaster ehaust.. What kind of horsepower am I pushing?
looking to change the throttle body and plainning on makes ram air system for it.. thanks
steve
Old May 31, 2003 | 01:54 PM
  #20
Booradley's Avatar
I saw this bellows that Speed Inc sells. It's called the Austin Bellows. Here's a couple of pics.
www.buickwe4.com/pic/DSC00021.jpg
www.buickwe4.com/pic/DSC00023.jpg
Old May 31, 2003 | 02:53 PM
  #21
JaysZ's Avatar
They're not worth 45 bucks but they look a lot better than that stock thing. This should be sold as an appearance upgrade only!
But talk about a nice profit margin- there must be about 3 dollars worth of manufacturing costs in there.
Old May 31, 2003 | 03:27 PM
  #22
z28200235's Avatar
jay yu said that your car with these mods
SLP lid, Magnaflow Muffler, P&P TB.
Dyno - 330rwhp/348rwtq
So mine i have airlid mod, Flowmaster exhaust and bellow.. . How much is a P&p TB? Are they better than bbk.. SO REALLY if I changed my throttle body I would have 330 rwhp? thanks
steve
Old May 31, 2003 | 03:34 PM
  #23
Aklaim's Avatar
Every car is diferent. There is no way you can tell if your car will make the same power as his if you have the same mods. Ive seen modded cars dyno less power than stock cars. Every car/engine is different. Also, that flowmasters exhaust you have is a big restriction. Im not trying to knock it, but I have the america thunder cat back on my car too and after getting my cut out installed it definetly woke things up....
Old May 31, 2003 | 03:36 PM
  #24
z28200235's Avatar
Every car is differnt? Do you mean bec the year. Mine is a 2002 Ls1 with 4,000 miles on it.
Is there a dyno in sanjose?
Im from hollister
thanks steve
Old May 31, 2003 | 03:39 PM
  #25
z28200235's Avatar
so you mean if evercar is diff..
Means that if I put my car on a dyno it might pull 335? I wouldn't think that is likely but could it be possible bec all cars are different..
Old May 31, 2003 | 03:43 PM
  #26
Aklaim's Avatar
Every car is different as in, no two cars are exactly the same. Ther are differences in the crankshaft, cam shafts, the blocks, rods, pistons, bolts. And sometimes some parts just produce more power than others. We have a stock 02' Z28 in our local car club that dyno'd 315 rwhp, and we had another stock car dyno 296. Every car is different. And yes there is a dyno in San Jose, lookup Mustang Ranch in Santa Clara, ATP turbo in Fremont, Thunder Alley in San Jose, and Speed Merchant in San Jose. I recomend either ATP Turbo, or Mustang Ranch.
Old May 31, 2003 | 03:45 PM
  #27
z28200235's Avatar
Theres a camro club in sanjose.. How often do you guys meet? You said a member had a 02 dynod at 315? Stock or what mods did he have? thanks
steve
Old May 31, 2003 | 03:47 PM
  #28
Aklaim's Avatar
Re-read the post. I stated he was stock. No mods whatsoever. I sent you a PM about the f body club.
  #29
z28200235's Avatar
For the guy with the 02 that pulled 315 on a dyno. What kind of rpm hitting 5100?
Old May 31, 2003 | 03:49 PM
  #30
Aklaim's Avatar
Do you have Aim? Lets take this off of this thread. My Aim screen name is DJaklaim...
