Hi all quick question
Old Oct 5, 2006 | 04:54 AM
My02Z28's Avatar
Ok im sure you guys here this alot an i did a little search, I have an 02 z28 m6 and i have Longtubes,catless-y an slpII catback and slp lid an K&N filter an short throw shifter, where do i wanna focus on next? im looking for some things to put on my christmas list...i was looking at a strut tower bar,but not really sure what i want next
Old Oct 5, 2006 | 06:28 AM
teke184's Avatar
Re: Hi all quick question
"where do i wanna focus on next?"
well that's really only a question YOU can answer
does it seem to have enough power for now? do you want to focus on handling? maybe some upgrades to the appearance?
the STB is a worthwhile mod in my opinion..but some people here don't seem to think so. another good upgrade is lower control arms, they'll help plant the tires better both straight line and curves. you can go with a $15 polyurethane torque arm bushing as well to firm up shifts and reduce axle twist. the biggest difference i ever felt was upgrading my sway bars. even if you just do the front it will handle much better.
something like the Raptor shift light would help get your shifting more consistent as well.
Old Oct 5, 2006 | 08:53 AM
AL SS590 M6's Avatar
Moderator
Suspension and frame.
Subframe connectors
LCAs
Torque arm and or Poly mount
LCA relocator brackets
Old Oct 5, 2006 | 09:13 AM
JakeRobb's Avatar
Super Moderator
+1 on subframe connectors and LCA's with relocation brackets. That's next on my list.
Old Oct 5, 2006 | 02:35 PM
My02Z28's Avatar
i guess the next thing i wanna do is to make sure i am getting the power to the ground the best way i can
Old Oct 5, 2006 | 06:31 PM
Bayer-Z28's Avatar
Subframe connectors
LCAs
Yeah. get the most out of what you have now.. Do some suspension work. LCA's and STB for starters. then you can do the SFC's... SHox and springs are kinda pricey and a lot of work. (6-8 hrs)
Old Oct 5, 2006 | 06:48 PM
GhostZ28's Avatar
I LOVED it when I did my STB, SFC's and LCA's with brackets AND 32mm front sway bar all at the same time. It was like a whole new car!
Old Oct 5, 2006 | 07:03 PM
mook99TA's Avatar
+2 on SFC's
LCA's
Panhard Bar
STB
Stall
Cam and a tune
Old Oct 5, 2006 | 09:29 PM
My02Z28's Avatar
Well a stall would do me no good since its an m6, How much work are LCA's and changing the LCA that wont change hight will it?
Old Oct 5, 2006 | 10:44 PM
Bayer-Z28's Avatar
^ nah. LCA's don't change the height. a couple ratchet wrenches help a LOT. but all in all about 45 min worth of work and 4 bolts all together. Pretty easy. Use a small tapered bar to help align the holes incase the rear shifts a bit..a philips screw driver could work also.
LCA's are a great mod for the small amount of time it takes to put them in. Definite traction differance!..
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
