HELP!!! Weird tapping noise.
Old Aug 7, 2009 | 05:07 PM
  #16
johnny6's Avatar
That sounds like crap, hopefully it's just a bad lifter. How is your oil pressure? I would drain the oil again to see if you have any metal shavings, or a bearing cap
Old Aug 9, 2009 | 01:55 PM
  #17
farva's Avatar
So for an update. I have done everything except take the heads off. I have used some sea foam in my oil and it has made the noise much more quiet. I am now at a loss. I think I am going to take it to a shop nearby and see what they tell me.
Old Aug 9, 2009 | 02:25 PM
  #18
Kraest's Avatar
Retired
How did the compression test come out? That will tell you most things....
Old Aug 9, 2009 | 02:39 PM
  #19
farva's Avatar
all the cylinders were almost exactly the same read out. i dont remember the numbers now. I had it at the shop on post. they were telling me that something with my vacume lines may be messed up. i couldnt find any leaks there. i dont even know what to do now. everyone keeps telling me something different!
Old Aug 9, 2009 | 03:32 PM
  #20
johnny6's Avatar
What's your oil pressure reading?? Did you look at the pushrods again? Get a set of new lifers and get rid of those rockers.
Old Aug 9, 2009 | 03:58 PM
  #21
farva's Avatar
My oil pressure does not go below 40 psi ever. When I rev the engine it goes up a little bit. I have not pulled the rocker arms again. The driver side of my engine does not tap at all. It is only the passenger side of my engine. Why would I remove the rocker arms. They are better than the stock ones. They are roller rockers. I think they have more lift than stock ones too. 1.65 vs 1.7 on the new ones.
Nayr
Mar 3, 2023 08:34 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Greg88
Aug 24, 2015 07:59 AM
colts0455
13
Aug 7, 2015 09:15 PM
