help!! trans mount problem
Old Oct 5, 2004 | 07:46 PM
zo6vette's Avatar
i bought a prothane trans mount and i replaced it today as i drove the car and when i get off the gas and as speed goes down i hear and clunking noise, it sounds like a thumping noise, all the bolts are tighten, trans member is even on the chassis, i dont understand why its clunking when i let off the gas?? it wasn;t like that today as i drove the car with the stock transmount, only thing i did was replace the mount and thats all and i even put a piece of rubber between the mount and the trans member but still i hear that thumping noise, what can this be? ive looked it over many times there's nothing binding up, bolts are all tighted up, does the trans mount need to be broken in?
Old Oct 6, 2004 | 05:18 AM
AL SS590 M6's Avatar
Moderator
Re: help!! trans mount problem
A lot of times poly mounts transmitt sounds and vibes that were already there, just masked by the rubber mounts.
Old Oct 6, 2004 | 06:40 AM
teke184's Avatar
check your LCA mounts, as well as your torque arm bushing.
either of those could be the noise you're hearing.
but it's probably just the natural noise, made more apparent by the solid mount
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
x7x7
Aug 15, 2002 06:49 PM
