Help!! Quickly Please!!
So i just drove my car over to the gym. not an hour later i go back out to it to drive home and it wont start. the keyless entry works and there is no lag in the horn. the lights turn out but when i turn my key over the radio will not turn on. the dash where the speedometer is will not turn on or show the mileage. i called my mechanic and he said it sounds like it isnt reading the key because the security light was still blinking. i tried putting the car in gear and starting it and still no luck. please give me some advice. already called off work sick last week and cant afford to miss anymore!!! thanks guys!!
I had a similar problem a few years ago. Put the key in, turn, and nothing, and my alarm would go off every time. Took it to the dealer, and they charged me something like $400 to fix it. This was before I started working on cars.
Sounds like the mechanic is right, and the resistor in your key isn't working right anymore; could be an easy fix if you know which key you need and can easily get one from your local dealer
keep the key out of the ignition for 3 mins i think....the security light will go out...then make sure the key is in all the way (wiggle it around and press IN) and then try it.
happens from time to time
My problem was the wires broke in the key cylinder. Very common problem apparently in all chevs.
Read our postings here Posts Click Here
I had the same problem w/ 2000 SS. One thing I did different was that I went to a junkyard & for $5 cut the VATS underdash pigtail connector out of a wreck (any GM w/ pelet key will work). Soldered the proper resistors together. The next time the SS stranded me I just swaped the jumper in & left the wire running up the steering column unconnected. Have not had the problem since. I believe the problem is in the pick-ups to head the resistance in the ignition switch.
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
