help please anybody! exhaust related
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
i need to remove my exhaust... its halfway done... if i can ever figure out how to pull the y-pipe off the single exhaust tube... from that clamp that DOESN'T COME OFF
the single tube and the muffler and tips can just be pulled out the back correct? the pipe has a large vertical bend so that it goes up and above the rearend... if i take hold of the muffler and twist as i am taking it out... it'll come out right? or will i have to cut something?
Re: help please anybody! exhaust related
Both times I've done this, the exhaust had to be cut. The only way I know how to take the exhaust off without any cutting is to disconnect part of the rear end, lift the car off of it, and slide it out that way.
just got a hacksaw...
anyone know how long it should take me?
just so i know if im doing something wrong?
lift?! pssh... pahhh... uck... blah!
im just doing this cause tv sucks right now =]
and i got a new hacksaw outta the deal
anyways... all done.... exhaust off... car lowered...
guess i should hit up summit for a new exhaust system.
anyone know if you have to drop the rear to install a slp loudmouth per chance?
No need to drop anything to install an exhaust system. It comes in sections that are clamped together. It's relatively easy once the stock system is out. Just depends on how **** you are with getting everything to line up "just right."
im very **** with such things...
tips?
find a flat surface to do the install...
use a level or something to get the tips straight...
a friend with an extra set of hands to hold things while you tighten everything down is a plus...
May 15, 2015 10:43 AM
