View Poll Results: Which Cam Would You Choose For My Setup
SI007 228 222 .588 .581 114.5
6.25%
SI1 222 222 .563 .563 114
0%
SI2 224 224 .581 .581 112
12.50%
SI3 224 224 .581 .581 114
18.75%
SI4 224 228 .581 .588 114
25.00%
SI5 231 237 .589 .595 112
25.00%
SI6 232 240 .595 .610 112
0%
SI7 238 244 .605 .612 110
18.75%
Multiple Choice Poll. Voters: 16. You may not vote on this poll
Help picking a cam.
Old Nov 12, 2006 | 07:01 PM
  #16
CAMAROZ28AQUINO's Avatar
Trex cam and a YANK 4000 stall, 3.90's will get u there
Old Nov 13, 2006 | 10:35 PM
  #17
sdavis2702's Avatar
i say SI4.... like everyone said there are many factors that apply when picking a cam. and you also got some stuff to sort out with your other parts... but for what you said you wanted i think that one will do you some good
Old Nov 14, 2006 | 06:30 PM
  #18
A&FLs1's Avatar
if its a daily driver such as mine is I would go with a cam such as 228/228 with 112 lsa. I would definitely stay under 230 dur. and not under 112 lsa so idle wouldnt be to lopey, i like the 112 lope though, sounds kinda mean but wont shake so bad it makes your whole body numb. I plan on getting TSP 228R in my future but not quite there yet.
Old Nov 14, 2006 | 07:26 PM
  #19
pwirch's Avatar
I got a recommendation from my shop .. Ed Curtis 228/232 custom grind. I don't know the specifics like lift and lsa. Anyone heard of Ed Curtis cams?
Old Nov 16, 2006 | 05:03 PM
  #20
Greed4Speed's Avatar
LSA is only part of the equation for lope. Duration plays a part too. Overlap is what causes the lope and its a product of both of these specs. You can have a tight LSA and short durations and a stockish idle because you have little overlap
Old Nov 16, 2006 | 05:06 PM
  #21
Never heard of him but that doesn't mean much. Who's grind is it (manufacturer?) and what are the other specs. You'll still be far short of your 425-450hp goal w/out ported heads.
Old Nov 16, 2006 | 06:09 PM
  #22
pwirch's Avatar
I've got ported LS6 heads. With everything I have I should be able to hit 425 right?
I've already got the following installed already:
3.73 Gears
SLP Underdrive Pulley
B&M Trans Cooler
160* Thermostat
MSD Wires
NGK Plugs
Pacesetter LT Headers
Pacesetter ORY Pipe
Dynomax Bullet 12"
I've got the following sitting on the floor of my family room:
LS6 Heads ported and flow tested by CFM Performance
TCI StreetFighter 3000
Transgo Shift Kit
MSD Coil Pack
Eibach Pro Kit
Spohn LCA Brackets
Spohn Adjustable Lower Control Arms
Spohn Adjustable Panhard Bar
SLP Oil Pump
Double Roller Timing Chain Set
I've got the following on order:
LS6 Intake from ls1speed.com
I've got the following coming from my shop:
Port my Throttle Body
Ed Curtis Cam 228/232 (I'm still waiting on the other specs)
All Valvetrain components
Full Tranny Rebuild
I really hope that I hit 425rwhp because everything here with the labor to install is around $8k.
Old Nov 17, 2006 | 08:50 AM
  #23
teke184's Avatar
i think you'll be pretty close to 425
depends on how the heads flow.
keep us posted
Old Nov 17, 2006 | 12:07 PM
  #24
pwirch's Avatar
I definitely will. Once everything is put in and I get the dyno tune and results I'll be posting either a " woo hoo " post or another " wtf " post with the results. I can't wait.
Old Nov 17, 2006 | 04:35 PM
  #25
Should be a decent combo, post up those cam specs when you get them.
Formula Steve
Sep 19, 2023 08:31 AM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
WobblySausage
Oct 7, 2015 02:44 PM
1994formy
Wheels and Tires
Sep 28, 2015 01:11 PM
MDZ28
11
Sep 24, 2015 09:15 AM
