Help Needed! Asap-bottom End??
Old Apr 21, 2003 | 05:34 PM
stik6shift98's Avatar
so in response to my low oil pressure i have concluded what i think the problem is
please give me your opinions and PLEASE tell me that IM WRONG
my symptoms:
low oil pressure
knocking
ticking
bottom end gone
and i think it mikght help to add that i just put it a head and cam package on it about 3 days ago.....
so what do u think???
Old Apr 21, 2003 | 05:36 PM
Tech's Avatar
Cam bearings might be toast.
Old Apr 21, 2003 | 05:37 PM
Josh-'04 GTO's Avatar
This would probably receive more responses if posted in LS1 Tech...
If your engine is knocking, a bearing probably ran dry somehow...perhaps due to the reduced oil pressure. Get ready for a rebuild.
Old Apr 21, 2003 | 06:50 PM
kmook's Avatar
Advanced Tech Moderator
Lets try this in LS1 Tech... moving.
Old Apr 21, 2003 | 07:20 PM
stik6shift00's Avatar
it is in ls1 tech....?
Old Apr 21, 2003 | 07:32 PM
Blkknight's Avatar
What kinda of knocking are we talking about here? Are we talking about a loud scary knock? Or just a quite knock? Does the knock kinda follow your lope and RPM's?
Mine just just went into the sh!tter as well and it was due to rod knock. Which I believe was caused by a bad ring since I was chugging oil like it was a keg at a frat party (went through 5qts in a month). It sounds like a LOUD knock comming from the engine bay. If it is this............. well um you may want to start pricing out forged parts.
But considering you just put a cam in there I would look around that area first. Look at your valvetrain to start. Was this installed by a shop or did you do it yourself?
Old Apr 21, 2003 | 08:18 PM
i got this professionally done at Speed Inc.
Old Apr 21, 2003 | 09:39 PM
95GRNZ's Avatar
Question
Have you thought about taking your car back to these "professionals" and have them diagnose it?
TS
Old Apr 21, 2003 | 11:48 PM
TS
my car is there right now
Old Apr 22, 2003 | 12:14 AM
whataretheodds's Avatar
your car is messed up if speed inc work on it...they messed up my car and i think they messed up your car to..they are terrible
Old Apr 22, 2003 | 12:22 AM
well i have been happy with them in the past but this time i got pissed.....
they have done good work for me in the past.....but this time
lets go thru my day of getting the car......
1. my aftermarket tach only works when my lights are off
2. nitrous switches didnt work at all
3. when i wanted to autotap my car neither of the cigerette lighters worked.....
4. and my autotap will not connect to the car.......
and now this!!!!!!!!!!!!!!!
Old Apr 22, 2003 | 12:35 AM
i know how u feel, well when my brother brought his car to finish line performance to get is header leak fix, which his headers where leaking due to poor quality installation from speed inc..the exhaust tech looked at it and guess what the leak was..it was from the pass side header flange that was open and in the middle was a nut so that the flanges won't move around..the two flanges both had the bolts on but, i gues that the lazy *** tech didn't finish the job cause when the two bolts mated up there was still a gap and still moving, so what they did was shoved a nut in the middle so both the flanges would't move..what kind of installantion is that? thats poor quality work from speed inc..
Old Apr 22, 2003 | 12:43 AM
my car
WHAT WILL I DO
Old Apr 22, 2003 | 12:45 AM
get it out from speed inc before they make it worse
Old Apr 22, 2003 | 12:48 AM
i dont think it could get worse
