Help with heads
Old Feb 21, 2007 | 07:54 PM
  #16
Zitty'sZ's Avatar
Patriot ls6 style heads are actually 035 casting heads that began life as truck heads with 72 cc chambers. Patriot welds the chambers up and then re-machines them to their specs, so I think that the chances of the heads being welded verses being milled to the 59 cc chambers is probably higher than most people think they are. Call Gunnar at patriot and ask him and I'll sure he will be more than happy to help you!
Old Feb 21, 2007 | 10:01 PM
  #17
Kraest's Avatar
Retired
If I bought some Patriot 035 LQ9 heads and they were advertising them as "LS6" heads, I'd sue the **** out of them. That's total bull**** if you ask me.
Check to see what kind of heads they are. If they are 243, then they are real LS6 heads. If they are anything else, they are lies.
If they are they 035 heads, then they were probably welded-up like Zitty said and will probably clear your valves since they wouldn't be milled.
Old Feb 22, 2007 | 04:41 AM
  #18
YBNORMEL's Avatar
Patriot did have alot of issues a few years back with the ls6 "style" head. I havn't read anything negative about them in a while
Old Feb 22, 2007 | 10:25 AM
  #19
Greed4Speed's Avatar
The 035's are sold as LS6 STYLE heads not LS6 heads and are welded up and cut to what ever combustion size you want.
They do have budget LS6 (146 casting) heads too.
Since Gunnar has been in there I haven't see any problems. The valve problems Patriot had years ago are the same ones AFR has been having.
I've read posts from Gunnar where has says that 2.055 heads aren't recommended for stock bored LS1's.
Old Feb 22, 2007 | 12:35 PM
  #20
Kraest's Avatar
Retired
I made 471/416 rwhp on 2.055 valve Dart 225s through the Vette drivetrain.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
