help, car going crazy
lol I figured I didnt have to put any oil in there but then he said that ( i guess i read it wrong) and got confused cuz i've never seen or heard of putting oil in it lol. but ya i get it now. i'll go buy some MAF cleaner and clean the SOB. thnx.
ok so i cleaned the MAF with the proper cleaner (almost used the whole can) and cleaned the connections really good, but I still have the SES light. I'm guessing it's because bank 1 and 2 are still lean?? IDK this car is stressing me out. any more ideas I could try?? i'm really trying to avoid taking it somewhere
The only time Ive dealt with this problem and it wasnt a dirty MAF sensor, it was the injectors. Swapped them out with some used ones and it cleared right up.
well i took it for a little drive after I did all that and it ran fine, just the SES light was on...I also thought one of the probs might be the injectors because of the two codes saying bank 1 and 2 were lean,hmm.... but how do i reset my comp? disconnect the battery? thanks for everyones help
To reset the computer
1) Turn the key on but do not start car
2) Pull the PCM Batt and PCM IGN fuses in the engine compartment
3) Wait 5 or so minutes
4) Turn Ign off
5) Replace fuses.
6) Start and drive car.
4) Turn Ign off
5) Replace fuses.
ahh.. I'm going to have to write that down..
UPDATE- I took out the car and drove it for about 20 min (longer than last time) and the SES light went off !!!! thank you everyone for helping me out. I'm hoping the light stays off lol thanks again I appreciate it a lot.
