help, car going crazy
Old Jun 20, 2007 | 12:03 PM
00ls100's Avatar
Unhappy help, car going crazy
hey everyone,
So I just recently started having problems with my car and did some searching but I am still a little confused.
so i'll start at the beginning.....
I was cruising down the highway 60-65 in 6th and went to pass someone. And being in 6th gear the car kind of lagged to pick up speed, no biggie, then it started gaining, then it hesitated it only did it once so I didn't really think nothing of it. but when I got off the highway it kept doing it when I would start from a stop and row through the gears every time i reached 2K or so rpm in 1st, and 2nd, sometimes 3rd. so now i'm getting freaked out. When I romp on it though and really give it some gas it didn't do it.
So fast forward to the next day..
I'm cruising down the street and the car starts hesitating again around the same rpm, hmm. I get to a stop and the car starts losing oil pressure AND the rpms start falling starts sputtering like the motor is trying to stay on. So I decide to pull into wal mart real quick grab a quart of oil. I put it in and the low pressure and rpm falling goes away yay. So i come to a conclusion to change the oil and think it will help. nope . I start it up cold and I get the sputtering from the motor right away.
Everytime I am idling or going slow these symptoms will come up ( hesitation has gone away) can anyone help me out?? is it my oil pump?? I thought i'd be as detailed as possible to avoid confusion. please give any info you can thank you.
Old Jun 20, 2007 | 01:57 PM
00ls100's Avatar
I drove it for lunch. the SES light came on. it's still trying to die on me. help me out guys
Old Jun 20, 2007 | 02:47 PM
WS6NIGHTMARE's Avatar
Your oil pump is not causing this problem. Your oil pressure is falling as a result of the motor. What is the code that is being shown from the light?
Old Jun 20, 2007 | 03:16 PM
00ls100's Avatar
I don't know, I don't have any type of scanner or computer equipment for my car ( I need some for sure though). so the only way to tell whats wrong is to scan it?
Old Jun 20, 2007 | 03:21 PM
Get to an Auto Zone, they will scan it and give you the codes for free. Usually a check engine light point right at the problem. Its not the only way, you could just start throwing parts at it
Of course you could just buy you a little scanner up there too, they have a small one I picked up for $50, good investment.
Old Jun 20, 2007 | 03:35 PM
2001NBMZ28's Avatar
Yup, get the code(s) read and write them down and post - don't worry about the description.
Old Jun 20, 2007 | 04:02 PM
00ls100's Avatar
lol I thought about throwing parts at it believe me. alright so i'll go to autozone and have them scan it for me, then post them up in here. thanks
on a side note. is a check engine light the same as SES light? I don't believe i've seen the check engine light light up in my car before. hmmm. thanks again though i'll post up the codes tomorrow.
Old Jun 20, 2007 | 04:27 PM
2001NBMZ28's Avatar
Yes, the SES and the check engine light means the same thing - we have the SES.
Old Jun 20, 2007 | 04:50 PM
Yep, just get us some codes and we'll help ya get it runnin right again.
Old Jun 21, 2007 | 08:56 AM
00ls100's Avatar
k went to autozone....so here goes
P0102
P0122
P0171
P0174
I thought I was only going to have one code lol. I know one of them said something about the MAF but don't remember. thnx for everyones help
Old Jun 21, 2007 | 09:48 AM
OK, so u have:
0102. MAF circuit low input
0122. TPS sensor low voltage
0171. Bank 1 too lean
0174. Bank 2 too lean
Start with 0102, check the engine sensor fuse in the fuse block under the hood. See if its blown, pretty common, could make them all go away. Of course check all the connections at the MAF and TPS.
Old Jun 21, 2007 | 10:13 AM
00ls100's Avatar
k, I will check all those out. I don't have the car with me ( i didn't want to make it worse so didn't drive it today) so I will post up what happens as soon as I can.
Old Jun 23, 2007 | 04:17 PM
rwb's Avatar
rwb
If the fuses are good, check to see if the MAF has any oil in it. That will kill it.
Old Jun 25, 2007 | 08:56 AM
00ls100's Avatar
k I checked everything out, and everything was connectect etc. but my car is still throwing the SES. what could it be?
^what and where do u put the oil in the MAF
Old Jun 25, 2007 | 09:00 AM
Kraest's Avatar
Retired
You don't put oil in the MAF.
What he was saying was to check to make sure the MAF isn't oily from excessive air filter lube or dirty. Get some electrical connector cleaner and spray the MAF if it's dirty.
Mike
