help, car going crazy
hey everyone,
So I just recently started having problems with my car and did some searching but I am still a little confused.
so i'll start at the beginning.....
I was cruising down the highway 60-65 in 6th and went to pass someone. And being in 6th gear the car kind of lagged to pick up speed, no biggie, then it started gaining, then it hesitated
it only did it once so I didn't really think nothing of it. but when I got off the highway it kept doing it when I would start from a stop and row through the gears every time i reached 2K or so rpm in 1st, and 2nd, sometimes 3rd. so now i'm getting freaked out. When I romp on it though and really give it some gas it didn't do it.
So fast forward to the next day..
I'm cruising down the street and the car starts hesitating again around the same rpm, hmm. I get to a stop and the car starts losing oil pressure AND the rpms start falling
starts sputtering like the motor is trying to stay on. So I decide to pull into wal mart real quick grab a quart of oil. I put it in and the low pressure and rpm falling goes away
yay. So i come to a conclusion to change the oil and think it will help. nope
. I start it up cold and I get the sputtering from the motor right away.
Everytime I am idling or going slow these symptoms will come up ( hesitation has gone away) can anyone help me out?? is it my oil pump?? I thought i'd be as detailed as possible to avoid confusion. please give any info you can thank you.
it only did it once so I didn't really think nothing of it. but when I got off the highway it kept doing it when I would start from a stop and row through the gears every time i reached 2K or so rpm in 1st, and 2nd, sometimes 3rd. so now i'm getting freaked out. When I romp on it though and really give it some gas it didn't do it. So fast forward to the next day..
. I start it up cold and I get the sputtering from the motor right away.Everytime I am idling or going slow these symptoms will come up ( hesitation has gone away) can anyone help me out?? is it my oil pump?? I thought i'd be as detailed as possible to avoid confusion. please give any info you can thank you.
Get to an Auto Zone, they will scan it and give you the codes for free. Usually a check engine light point right at the problem. Its not the only way, you could just start throwing parts at it
Of course you could just buy you a little scanner up there too, they have a small one I picked up for $50, good investment.
lol I thought about throwing parts at it believe me. alright so i'll go to autozone and have them scan it for me, then post them up in here. thanks
on a side note. is a check engine light the same as SES light? I don't believe i've seen the check engine light light up in my car before. hmmm. thanks again though i'll post up the codes tomorrow.
k went to autozone....so here goes
P0102
P0122
P0171
P0174
I thought I was only going to have one code lol. I know one of them said something about the MAF but don't remember. thnx for everyones help
P0102
P0122
P0171
P0174
OK, so u have:
0102. MAF circuit low input
0122. TPS sensor low voltage
0171. Bank 1 too lean
0174. Bank 2 too lean
Start with 0102, check the engine sensor fuse in the fuse block under the hood. See if its blown, pretty common, could make them all go away. Of course check all the connections at the MAF and TPS.
You don't put oil in the MAF.
What he was saying was to check to make sure the MAF isn't oily from excessive air filter lube or dirty. Get some electrical connector cleaner and spray the MAF if it's dirty.
Mike
