Heads and Cam VS. procharger
Old Mar 7, 2007 | 06:07 PM
SpeedDemon02SS's Avatar
sorry, didnt know if this should go here or in forced induction.
How much power can i gain from a good set of heads & cam. or just a cam? on a stock internals engine. mods listed below if that helps. Just curious because i wanted to go the procharger route, but i can get a nice set of heads & cam for half the price. Is this better or worse for hte life of the engine?
any feed back would be appreciated.
thanks.
Old Mar 7, 2007 | 06:31 PM
JakeRobb's Avatar
Super Moderator
From a good cam, you could see as much as 50rwhp, assuming you get a good tune. With heads, that number goes WAY up. With a stock bottom end, you're looking at 450+ rwhp with all of the usual supporting mods. I know Kraest's old C5 made 471. To get higher than that with a stock bottom end, you'd be looking at a VERY agressive cam.
With a supercharger, assuming you leave the engine internals alone, you can get quite a bit higher. The car will have nicer manners on the street, and your cruising fuel economy will be better than with a heads/cam package. I'll use Kraest as an example again here -- I think his supercharged C5 (which he bought after selling the 471hp one) made ~540 rwhp.
It's probably important to note that you're not going to hit 450rwhp with a heads/cam setup that costs half of what a supercharger costs.
I don't see headers on your mod list -- that's restricting you now, and will restrict you a lot more after you install a heads/cam package or a supercharger. Stock LS1 manifolds are pretty good, but a set of longtube headers will free up quite a bit of power.
It's also important to note that anywhere north of 400rwhp, you're looking at stressing several components of your stock drivetrain beyond what they were designed to handle. At the very least, you'll need a better clutch, and you should probably think about investing in a stronger rear end.
I'm just spewing stuff I learned from the other guys here. Hopefully people with actual experience will chime in.
Old Mar 7, 2007 | 07:14 PM
funny you mention it. pacesetter LTs are on their way, as well as a new cluch and strange 12-bolt later this summer :-). I really watned to do the procharger, but i had heard taht i could get the same from heads and cam for 1/2 the price. I guess my source wasnt that accurate. should i look into a cam with the blower? or will the blower on a stock internals engine be fine. should i upgrade antyhing else in the engine? rods, bearings, etc?
Old Mar 7, 2007 | 07:16 PM
myslowcamaro's Avatar
whats the procharger go for now, $5400?
h/c= $1900-3000
stroker kit=$1900
n2o=$1000
600+rwhp= ~$4900+labor ($5900 total)
i spent $2300 for h/c, installed. with my other mods im at 420rwhp. i can get a 382/383 stroker kit for as low as $1300 (eagle brand) on e-bay if you catch it right, otherwise $1700. so with that and n2o you are looking a t a sick engine and its forged so you can add a s/c on later anyway.
Old Mar 7, 2007 | 07:59 PM
yes, about 5400 for the procharger and twin intercooler set up.
but the thing abou the blower, is it is pretty docile on the roads when you want it to be. not to mention, i dont need to rebuild my engine, i only have 35,000 miles on it. i want to save the rebuild for when i need it. and when that is the case, i already have the blower too.
Old Mar 7, 2007 | 08:25 PM
Kwiksilverz28's Avatar
Another vote for the blower. I love the whine too :-)
Old Mar 7, 2007 | 08:34 PM
Originally Posted by robvas
Do it all. Heads, cam, built motor, blower, 600+ hp
sounds great. anyone wanna donate a dollar to the cause?
im gonna stick with my current plan. blower on a stock motor. when the motor starts to go, built motor with a blower. procharger said they can even rebuild the blower (bearings and such) and make it like new.
Old Mar 7, 2007 | 09:31 PM
Yup. I am only pushing 5psi, so hoping it will last a while too. Just remember that there is a lot more than just the blower. I did fuel pump and injectors, water pump belts and hoses, and tuning software/dyno time. Plus I am upgrading the clutch, did rims and tires, guages, etc etc. Lot more than just the ATI kit....
Old Mar 7, 2007 | 10:37 PM
i am going to replace those thing. the ATI kit comes with new belts and injectors. not sure about the fuel pump, but if it doesnt, im going to get a better one, as well as a water pump. also going to upgrade the radiator to keep that bad boy cool. i just dont want to replace the internals of a 35,000 mile engine.
Old Mar 7, 2007 | 10:54 PM
SSpdDmon's Avatar
Go with the Procharger. What everyone seems to be forgetting is the torque factor. A great rwhp H/C setup typically has lower torque numbers (ie: my decent H/C setup w/ numbers in sig). A Procharger on the other hand will have a much nicer torque curve....and that's where the "pull" factor comes in.
Old Mar 7, 2007 | 11:13 PM
yea, with what i have and what im doing, 550hp/550tq is not gonna be out of the question with 5psi. that should make for a nice day of mustang abuse.
Old Mar 8, 2007 | 04:46 AM
magius231's Avatar
yeah, there's a problem with the procharger figures...
Forced Induction is ALWAYS more expensive than you think it is...if you don't believe it, go check out the FI section at LS1TECH and look at the sticky titled "The REAL price of forced induction". Even for a basic Procharger kit making around 450rwhp you can expect to pay $6500+ when all is said and done.
Heads/cam with a stock bottom end you can make as much as 520rwhp with a well set up combination, I.E. TFS heads, Fast 90/90, matching cam (not necessarily huge), bolt ons, etc. You're still going to have $4500 in your motor though.
Stroker you could make 620rwhp, but your looking at probably $7500 at the low end in your motor alone. At this point the price difference between FI and N/A starts evening out...
IMO if you want more than 500rwhp go FI. If your happy with less, stick with N/A.
Old Mar 8, 2007 | 08:16 AM
im aware of the costs. FI makes the most sence for me because i do want a car with 550-600hp that i can drive on the road. I dont mind the extra money. and once again, there is no reason to re-build a low milage motor. besides, the extra points for the kick *** factor of a blower.
and the whine...
Old Mar 8, 2007 | 08:18 AM
Kraest's Avatar
Retired
Since my name has been mentioned already, I'll comment with my experiences since I've owned all 4 LS1 setups (cam-only, heads/cam, forced induction, and stroker):
The Heads/Cam C5 was a fun car, but not very friendly on the street and made power high. That's what you have to remember: If you're putting a bigger cam, better flowing heads, and and intake in a 346ci motor and changing the range of the motor's powerband, then you are going to lose some of your low-end. My heads/cam car turned on at around 4500 and made power until 6800. Powerband = 2300 rpm 471rwhp/416rwtq through a 6-speed.
The Procharged car was a much more street friendly car to drive and could have always made more power by doing a pulley swap and using race fuel It made MUCH more low-end than the heads/cam setup and peaked nearly as high. It turned on around 3500rpm and ended at 6500. It put down 514/466, which is 50 more rwtq through the automatic.
Obviously the way to go is a big cube stroker motor, but that's the most expensive. My 408 makes big low end and high end power. Power comes on around 3500 and pulls to 7200 rpm (7400 rpm rev limiter) Numbers in sig.
With that said, if I had a choice to rank them, I'd say that power and fun (like usual) is proportional to the amount of money spent (unless you're talking about spraying the house down, which IMO is pretty pointless since you never have that power readily available to you at all times)
Old Mar 8, 2007 | 08:23 AM
i look at your descriptions, and the procharger is 100% of what i want. I want the power always there so i dont want spray. i want the car to be road friendly because i do drive it on the street. i want low end power over the high end. and i dont want to rebuild my motor, it only has 35,000 miles on it.
