Heads and Cam Help
Old Oct 20, 2006 | 11:57 PM
nakedwarrior's Avatar
Heads and Cam Help
I just purchased the PRC 200cc Terminators and TSP 228R cam. I upgrades my timing chain to a comp adjustable ls1 ls6 chain and wasn't sure if I need to upgrade my rockers or not? Are the stock rockers good enough or will I get alot more power out of new better rockers? I think the stock ones are 1.7 the cam specs are as follows.
228/228 .588 .588 LSA 112 +2 advance
Please help me so I make the right decision.
Old Oct 21, 2006 | 09:09 AM
myslowcamaro's Avatar
Re: Heads and Cam Help
keep the stockers and spend the $600-1000 on other mods.
Old Oct 21, 2006 | 09:50 AM
SOMSS's Avatar
He's right, spend that money where you need it! You can also save yourself some money by not purchasing the Adjustable timing chain and getting a LS2 timing chain instead.
Old Oct 21, 2006 | 01:09 PM
What about the FAST 90/90 and should it be ported; if so then where can I get that done? Does it really help...
Old Oct 21, 2006 | 01:29 PM
teke184's Avatar
no need to port it for that h/c setup...it will flow just fine
Old Oct 21, 2006 | 02:09 PM
Do you think porting will increase the hp and tq?
Old Oct 21, 2006 | 04:27 PM
teke184's Avatar
not really...they already flow like crazy.
i was almost gonna reccomend not to do the 90/90 on that setup...since the cam is fairly mild...the real gains with the fast on on big h/c setups.
on that setup going from an ls1 intake to an ls6 would gain you 15hp...for $300
going from the ls1 to the FAST 90/90 will gain you 25hp...and most of that will be in the high rpms...for the bargain price of $1200
StansZ28
Feb 19, 2015 07:39 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
