Heads and Cam Help
Heads and Cam Help
I just purchased the PRC 200cc Terminators and TSP 228R cam. I upgrades my timing chain to a comp adjustable ls1 ls6 chain and wasn't sure if I need to upgrade my rockers or not? Are the stock rockers good enough or will I get alot more power out of new better rockers? I think the stock ones are 1.7 the cam specs are as follows.
228/228 .588 .588 LSA 112 +2 advance
Please help me so I make the right decision.
Re: Heads and Cam Help
not really...they already flow like crazy.
i was almost gonna reccomend not to do the 90/90 on that setup...since the cam is fairly mild...the real gains with the fast on on big h/c setups.
on that setup going from an ls1 intake to an ls6 would gain you 15hp...for $300
going from the ls1 to the FAST 90/90 will gain you 25hp...and most of that will be in the high rpms...for the bargain price of $1200
