Heads and Cam
Old Jan 26, 2006 | 08:26 PM
stmz28's Avatar
Heads and Cam
I am looking to do a head and cam set up to my car looking for 450+ rwhp. The setup I was going to do is dart heads and a G5X3 cam has any body did that set up if so how do you like it and what power did it make. If anybody has a setup they like makeing that power or more can you list it. The car is going to be steet driven and weekend track car. Thanks for the help
Old Jan 27, 2006 | 06:54 AM
teke184's Avatar
Re: Heads and Cam
did a quick search...couldn't find it...what are the specs on the cam?
even with that cam 450rwhp won't be easy to hit. at least you have the supporting mods to do it.
from what i've seen and read that cam alone will yield about 400rwhp on stock heads. not sure the Darts will give you the other 50hp. i think you'll be close, and it will be one hell of a engine combo.
you may be better off looking at some of the ported 5.3L heads, i think they flow a little better.
Old Jan 27, 2006 | 09:20 AM
stmz28's Avatar
Re: Heads and Cam
the cam specs
G5X3
2xx
2xx
.600
.610
112/114
Old Jan 27, 2006 | 09:37 AM
teke184's Avatar
Re: Heads and Cam
well that helps...
i knew it was in the 23x range, i think the duration is something like 236/242...
with that big of a cam it's gonna be a handful on the street i think. tolerable yes...easy to handle no
Old Jan 27, 2006 | 11:39 AM
2002ss's Avatar
Re: Heads and Cam
You are running times at the track that are about what I am running and I have 420 on dynojet at the wheels. I will get a bit more when I lean it up a bit, but not much. you have to be close to that 450number already. What have you had it dynoed at?
Old Jan 28, 2006 | 05:20 PM
Kraest's Avatar
Retired
Re: Heads and Cam
Dart 205 or 225s with the Futral F-14 and a FAST 90/90 setup will exceed that and drive nearly like stock.
Mike
StansZ28
Feb 19, 2015 07:39 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
