headers and Y pipe
Old Feb 25, 2008 | 03:18 PM
bcphilly01z28's Avatar
headers and Y pipe
what would the difference be if i only had headers with no off road y pipe and just kept my magnaflow setup with pacesetter headers?
Old Feb 25, 2008 | 03:30 PM
ss.slp.ls1's Avatar
Headers are definitely one of the best bang for your buck mods. ORY does help, but it should be noticeable regardless. What car do you have, what headers are you getting, mids, LT's?
Old Feb 25, 2008 | 03:48 PM
i have an 01 z28 A4, and im looking to get the pacesetter coated long tubes
Old Feb 25, 2008 | 03:51 PM
ss.slp.ls1's Avatar
I am not too familiar with header installation on an LS1, but long tubes might require replacing/modifying the factory y-pipe. Someone will chime in and make it more clear. As I said, regardless, some pacesetter LT's alone will definitely be a gain.
Old Feb 25, 2008 | 03:53 PM
ok cool thanks a lot
Old Feb 26, 2008 | 07:07 AM
teke184's Avatar
there is basically no way to mate the stock ypipe up to long tubes.
so basically....you have to get one.
Old Feb 26, 2008 | 08:19 AM
what kind of Y pipe should i get that would still pass emissions? do i need the catted Y or can i get an ORY
Old Feb 26, 2008 | 08:20 AM
2000GTP's Avatar
If they are going to do a visual, then you would want to get the catted y-pipe. However, you could still fail emissions because the cats are not in their respective factory locations.
Old Feb 26, 2008 | 08:49 AM
ss.slp.ls1's Avatar
Hopefully you don't live in Cali, otherwise you can toss the whole idea of LT's and start shopping around for shortys or mids.
Old Feb 26, 2008 | 08:55 AM
i live in pa...hopefully the catted Y pipe will still pass emissions. how is the performance and sound with the pacesetter LTs and magnaflow exhaust?
Old Feb 26, 2008 | 09:22 AM
2000GTP's Avatar
Performance will be very good improvement, as for sound, that is always a matter of preference but that combo usually has good things said about it.
Old Feb 26, 2008 | 10:22 AM
00ls100's Avatar
there's some combos that work with pacesetters. you can get the combo from TSP with an ORY or with a catted Y, whichever you prefer. you could look around and see if there are other Y-pipes that will fit with the pacesetters, or you could also get a custom one fabbed up at a local exhaust shop. the choice is yours... hope i helped
Old Feb 26, 2008 | 11:28 AM
ss.slp.ls1's Avatar
You're in for a treat, performance over stock will be noticeable, and the sound will be sweet. I like the way mangaflow sounds.
Old Feb 26, 2008 | 11:46 AM
teke184's Avatar
magnaflow will sound good with cats. without them it tends to get a bit raspy on the top end.
nothing horrible, just the nature of a very free flowing system.
figure going from bone stock exhaust to LTs, catted Ypipe, and a magnaflow exhaust...25hp to the wheels.
Old Feb 26, 2008 | 12:57 PM
Kraest's Avatar
Retired
I just went with the Pacesetters with the X-pipe to true duals. I think the X-pipe/true dual is around $450, then there's no need for any other exhaust concerns.
TitoPR221
May 26, 2015 12:20 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Russ95Z28
Apr 23, 2015 01:55 PM
Queens94z28
Mar 23, 2015 08:06 AM
alphaauto
Jan 23, 2015 07:42 AM
