Headers??????
Old Oct 22, 2004 | 04:06 PM
Articblast's Avatar
Headers??????
Okay, should i get MAC mid lengths, Pacesetter, Flotechs, Hooker. I want a set of headers that are the easiest to install, great seal, and performance gains. I know where I can get pacesetter uncoated for $245, but i think I read they only give 8-12 rwhp.........waht happened to a solid 40 horses to the rear with headers????
Old Oct 22, 2004 | 05:06 PM
teke184's Avatar
Re: Headers??????
"waht happened to a solid 40 horses to the rear with headers????"
somebody was smoking crack...no header will give that...well maybe longtubes replacing stock manifolds on a 1000hp engine
flowtech longtubes are great and last i checked were around $400
you don't need to worry about emissions do you?
Old Oct 22, 2004 | 07:11 PM
CrippleFightin's Avatar
Re: Headers??????
Jet Hots
Old Oct 22, 2004 | 08:02 PM
Articblast's Avatar
Re: Headers??????
No, I'm outside the city, so no emissions check. I think I can get a MAC setup with the y w/out cats for $470. Is that a descent set up?
Old Oct 22, 2004 | 08:48 PM
SHIZNIT's Avatar
Re: Headers??????
Another vote for long tubes!!!!
Old Oct 22, 2004 | 10:08 PM
teke184's Avatar
Re: Headers??????
i bought my flowtech longtubes with ceramic coating, offroad ypipe, o2 extensions, metal gaskets (reccommended), egr and air blockoff plates and gaskets (just in case one broke) for about $600
install was a snap...check out my detailed write up on page 11 of my webpage in the sig
Old Oct 22, 2004 | 11:18 PM
Antz97ZNJ's Avatar
Re: Headers??????
Wish we had the option to run Longtubes (or even mid lenghts at that) legally, go LTs all the way...
Old Oct 22, 2004 | 11:40 PM
Onez4u2bn's Avatar
Re: Headers??????
QTP Long Tubers!!!!!!!! Gonna cost you about $800 but you can get the most gain out of them especially with the high volocity collector at the end of em.
P.S. A SLP Loudmouth will compliment it well
Old Oct 24, 2004 | 12:46 PM
SLPZ28's Avatar
Re: Headers??????
Ok I do think headers can net you 50RWHP but are they rating them at the motor or rearend? With my SLP LT I picked up around 33RWHP and 40RWTQ! Not bad! But the more you do the more it will help those ####.
Old Oct 24, 2004 | 01:58 PM
Greed4Speed's Avatar
Re: Headers??????
Long tubes are long tubes. The difference in prices reflects the materials used not performance benefits.
The Macs can perform right up there with LTs. When I was shopping I found that Flowtech and Pacesetter LTs and ORYs were cheaper than Mac's set up, but then I found a good deal on a used catted set up so I went that route.
Go which ever way you want. LT or mid. You can't really go wrong.
http://www.ls1.com/forums/showthread.php?t=498439
Old Oct 24, 2004 | 06:01 PM
Jack D Ripper's Avatar
Re: Headers??????
QTP High Velocity Merge Collector Headers wil the most gains amoung the F Body headers. SOme have seen 40hp.
Old Oct 24, 2004 | 11:25 PM
Onez4u2bn's Avatar
Re: Headers??????
Well that all depends. The main reason I said QTP is because I heard they had the most gain and absolutley NO clearance issues at all. Which will come in handy going over them speed bumps.
Old Oct 25, 2004 | 07:37 PM
Re: Headers??????
See my link and scroll down to headers.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
