Header Questions
Old Aug 30, 2003 | 09:53 PM
allnet777's Avatar
Question Header Questions
I am planning on buying either Hooker, or Jet Hot LT's in the near future. If I buy the headers, will that come with everything I need for the install? Do you need an aftermarket Y-pipe, or will stock work? Even if the stock Y works, is it recommended? Am I going to lose some hp with a stock Y? Finally, Which would you pick out of the two if your going for most RWHP. What about difficulty to install?
Old Aug 31, 2003 | 11:10 AM
SunsetWS6's Avatar
When you get headers you'll need new GM gaskets. All the clamps ect should come with the headers. You can re-use the stock manifold bolts. If you run an offroad y-pipe you'll need 02 extensions & a pair of o2simms. That's about it. You can not use your stock y-pipe, you'll need to buy whatever y-pipe needed for whatever brand headers you get. Just about every header has it's own y-pipe. I'm not a fan of either headers & they are both the same, so either way you go one isn't going to be better. I recommend PPC, Kooks, TR, TTS, FLP headers.
Old Aug 31, 2003 | 01:30 PM
GrdLockV6's Avatar
I had no problems w/ my hooker headers. They also came with gaskets and new header bolts. I bought the Mufflex y-pipe which fit up to them nicely.
Installation is a bitch though, so be prepared to spend a good day doing it
FLP's are very nice, especially with the ability to swap cats and off-road pipes, but $1,200 for headers is just too much IMO.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
