A Header is a Header????
Old Mar 16, 2005 | 08:18 PM
XxCamaroZ28xX's Avatar
I want to get headers for my car and I was looking for the best one. SLP says 41HP and 58Ft Ibs. Are these numbers for real?? Some of my friends tell me a header is a header and that I shouldn't waste money on the costly SLP headers. What would you recommend??
Old Mar 16, 2005 | 09:15 PM
MustangKilla's Avatar
Re: A Header is a Header????
from what i hear slp headers have the worst clearance and all slp **** is overpriced. Rule i have learned from this board, dont buy anything slp except the lid.
Old Mar 16, 2005 | 09:55 PM
00ls1's Avatar
no way is there 40+hp and 50+lb ft of tq coming from headers unless the motor is highly modified.. id guess 20-25hp with a simple header bolt on
Old Mar 16, 2005 | 10:05 PM
Antz97ZNJ's Avatar
Id say all long tubes perform very similar...theres other much cheaper options though...pacesetter Lts, hookers,flowtech, etc
Old Mar 17, 2005 | 07:17 AM
teke184's Avatar
"SLP says 41HP and 58Ft Ibs"
man i have some ocean front property in colorado for you if you're interested!!
i've seen several dyno tests of headers. on a stock internal engine, just bolt ons...15-20hp is about right for LTs
given the same primary size, and collector size...all LTs should yield similar results +/- an accepted deviation.
Old Mar 17, 2005 | 09:39 AM
darrens99formul's Avatar
All LT headers will net you about the same gains. The main differences between the different brands (kooks, slp, pacesetter, ect) are fitment and what they are made of (stainless steel vs mild steel vs coated vs uncoated).
SLP's are stainless steel but are known for poor clearance issues. They scrape alot and lowered cars need to steer clear of them or so I am told. Kooks are also stainless steel and often referred to as the "cream of the crop". They are the best IMO but are also among the most expensive. Coated Pacesetters are the best "bang for the buck" IMO if money is tight and you don't care about not having stainless steel.
I kind of like the dynatech ones for those that want a complete setup with catted Y-pipe. Mild steel isn't as good as stainless but I have seen some good sales on them and the fitment is supposed to be good as well.
Good luck
Old Mar 17, 2005 | 10:06 AM
StealthZ28's Avatar
Texas Speed and Performance has a great deal on Pacesetters and the TSP catted-y pipe. A good set up. Very pleased with mine and the deliverly was fast.
Old Mar 17, 2005 | 05:13 PM
350TPI5SPEED's Avatar
what about edelbrocks new ti-tech lts? anyone have them yet? $399 doesnt sound too bad either
thanks
jay
Old Mar 17, 2005 | 05:25 PM
blind527's Avatar
20-25 HP seems pretty common on LT header applications. I would say about a total of about 33 with the LT's, Y pipe, and cat back.
Old Mar 17, 2005 | 05:51 PM
SFB767's Avatar
What made you go with a catted y-pipe and not an ORY, emissions and local laws?
How do the Pacesetters sound with the catted y-pipe?
Old Mar 17, 2005 | 07:02 PM
rally2247's Avatar
Where did you get those numbers from? Did you speak to a SLP rep???
Old Mar 17, 2005 | 07:53 PM
96SFLZ's Avatar
Their website: http://www.slponline.com/view_product.asp?P=30049
Gain up to 41 horsepower and 58 lb.-ft. of torque, depending on your application!
Of course the application which gained 41hp/58tq was not even remotely stock. Prolly had at least H/C and every bolt-on besides headers...then picked up that power after the stock manifolds were swapped for the LTs.
And yes, most LTs should be good for about 20-25rwhp.
Old Mar 18, 2005 | 02:52 AM
StealthZ28's Avatar
Since I live in New York State, the emission laws are really strict. Not only do we have to pass the sniffer, but also a visual. So instead of risking it, I got the catted-Y. The cats are hi-flo and they flow so good, the computer will still throw a code. Therefore, I still run the o2 sims. As far as the sound, it's just alittle louder. But with my GMMG, it still sounds awesome.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
