Head search...LS2 casting 799 fit ls1????
Old Feb 3, 2009 | 01:38 PM
  #16
Marc 85Z28's Avatar
Originally Posted by Sunsetmaro
Recently however, I found a set of 799 casting ls2 heads. From the description here and what I have read, they flow as good or even better then the afr heads.
Those heads will NOT make anywhere near as much power as the AFRs - not stock anyway. Also, those chambers will be too big for your LS1. If you get the 799 heads, figure at MINIMUM milling them. Milling will be required just to maintain a stock compression ratio, but it will limit the size of the cam you can run on stock pistons. The only way they will perform on par with the AFRs is with substantial milling and porting, and a good valve job. Not such the great deal you were expecting
Old Feb 4, 2009 | 06:59 AM
  #17
Chrome383Z's Avatar
Aren't the 799 chambers the same size as the 243 chambers at 65cc?
I thought they where, that'll bump your compression up a little from the 68cc 241 ls1 heads.
Now granted, it wouldn't be 59cc like most like to go...
*Emilia*
May 13, 2015 09:05 AM
95chwagon
Feb 28, 2015 12:02 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
