Guess My Dyno Numbers
Old Jun 8, 2005 | 09:17 PM
Schmidt519's Avatar
Mods
Lid
K & N Air Filter
Whisper Ram Air
Jet Hot Header 1 3/4" w/ Cats and Y-pipe
Borla 3" Adjustable Cat-Back
Previous ^^ Dyno'd 334 RWHP (NO TUNE - Hit speed limiter)
All of below getting installed since wednesday morning
230/234 601 112 Dominator Cam
LS6 Intake Manifold
SLP Oil Pump
Double Roller Timing Chain
Underdrive Pulley
30 lb. Fuel Injectors
Spark Plugs
Spec Star Clutch Kit Stage 3 w/ billet flywheel
160 Thermostat
Ported Throttle Body
Professional Tune
Will have the final numbers on Friday.
Old Jun 9, 2005 | 02:09 AM
Kurt Crosbie's Avatar
Re: Guess My Dyno Numbers
I'm guessing at least 400rwhp.
Old Jun 9, 2005 | 06:30 AM
teke184's Avatar
similar setup to me...
but my clutch was slipping and the tune wasn't great.
i'm gonna say 396hp/380# torque
Old Jun 9, 2005 | 09:54 AM
It must be nice to have ls1 heads. You guys can bolt on 400rwhp.
Old Jun 9, 2005 | 11:34 AM
Compstall's Avatar
500 + or - 200
Old Jun 9, 2005 | 11:52 AM
teke184's Avatar
"It must be nice to have ls1 heads. You guys can bolt on 400rwhp"
geez, i made a comment in the LT1 forum about how much less flow the LT1 heads have compared to LS1 as a simple observation, and i got flamed and insulted by half dozen people.
comments like
"welcome to 1997"
"what a ***, using it as a reason to state the obvious"
but yeah...it is nice to have that potential
Old Jun 9, 2005 | 02:45 PM
myslowcamaro's Avatar
hi mike. my guess is 399.2rwhp. did your brother get the c5 sunday?
Old Jun 9, 2005 | 03:16 PM
Yes, the ls1 heads come with far more flow from the factory. I just don't like it when people try to say that either is superior. Each is good in its own right. They're both smallblocks. The lt1 you can put 11* or 18* nascar heads on. The ls1 is friendlier to bolt-ons, etc. It is obvious that the ls1 would be better though, simply because it is a newer design. That just how it works. It's just not as popular yet because its fairly new. Once it gets cheap enough and there are enough aftermarket parts to modify it, it will then put the lt1 out of business. Kinda like how they used to use wooden wheels. Or how meat used to be preserved with salt instead of freezers.
Old Jun 9, 2005 | 04:18 PM
whats a freezer?
Old Jun 9, 2005 | 04:27 PM
very funny.
Old Jun 9, 2005 | 04:53 PM
Kraest's Avatar
Retired
No need for the fuel injector change just yet
I'm gonna guess around 400rwhp.
Old Jun 9, 2005 | 05:03 PM
Its erdiculously sad how much stock lt1 heads suck. If I put a 230 cam in my lt1, i would probably make about 350rwhp as opposed to your 400.
Old Jun 9, 2005 | 07:40 PM
nevermind the heads, the brakes really suck. schmidt519 ran against each other and after 2 runs neither one of us had any brakes left. we pulled over to let them cool down. we both agreed to save up for wilwood brakes. but back to the heads....ive been told the stock ones can be ported and flow as good or better than the afr's. whats your take on that? i was told it can be done for $1200.
Old Jun 9, 2005 | 08:27 PM
Schmidt519's Avatar
Stock Injectors can only handle 350 RWHP
Old Jun 9, 2005 | 08:31 PM
Schmidt519's Avatar
6 piston stainless steel brakes are next on my list
