Gotta Problem
Old May 1, 2005 | 11:24 AM
My00Camaroz28's Avatar
Gotta Problem
And dont know what it is. My check engine light has been on ever since my header install and all of the sudden it starts to blink. My car is getting all bumpy and feels like everything is shaking. The exhaust note is different and car feels like it has no power. I pull into a parking spot as soon as this happens and turn off the car wait 10 sec and turn it back to see if it stops but it still blinks. Does anyone know what my problem might be? I didnt just get gas, and I still have 3/4 of a tank so its not that. I was thinking maybe a misfire?
Old May 1, 2005 | 11:52 AM
2001NBMZ28's Avatar
Re: Gotta Problem
Man, sorry to hear this - is there any way you can get someone to pull the code(s) for you and post them?
Old May 1, 2005 | 12:18 PM
SSpdRcr's Avatar
Re: Gotta Problem
Im having the EXACT same problem yesterday after i installed my LT headers on my 00 SS.. Everyone is saying its a misfire so im gonna change the spark plugs and wires.. That should fix it..
Old May 1, 2005 | 12:37 PM
Re: Gotta Problem
Yea im gonna try to get the codes read at some place later on. Does everyone else agree that its prolly a misfire or any other ideas?
Old May 1, 2005 | 01:01 PM
2001NBMZ28's Avatar
Re: Gotta Problem
Probably is a misfire. Check for any burnt plug and/or 02 sensor wires, make sure everythings plugged in tight. Knowing the code will help nail it down.
Old May 1, 2005 | 02:15 PM
Re: Gotta Problem
Yea turns out it was a misfire in cylinder 2. Is it ok to drive a little with this or should I try to not drive until fixed?
Old May 1, 2005 | 02:54 PM
2001NBMZ28's Avatar
Re: Gotta Problem
If you're just going a couple miles at moderate speeds to limp home you'll probably be OK. Change that plug/wire first if you can and see if the light stops flashing or goes steady - I'm assuming it's just an electrical problem, if you hear any strange noises don't drive it.
Old May 1, 2005 | 04:13 PM
Re: Gotta Problem
Damn they make it so hard to get to the spark plugs even the #2. I tried about everything and finally got a extension to fit but that old plug wont budge, been trying to get that thing out for 30 min.
Old May 1, 2005 | 05:04 PM
2001NBMZ28's Avatar
Re: Gotta Problem
I always thought it was easier w/headers, guess not. Remove the air pipe first if you have to, should be able to get to it with just a plug socket and ratchet. Hang in there...you'll get it.
Old May 1, 2005 | 06:47 PM
SSpdRcr's Avatar
Re: Gotta Problem
I have to replace my plugs and wires tomorrow too.. How is the install? Any tips?
Old May 2, 2005 | 01:20 PM
spoonjimlt1's Avatar
Re: Gotta Problem
Ive done it about 10 times ive found the best and most pain free way to do it is take the coil pack off the pass. side to free up the extra room. the coil pack it self may give you some trouble on the rear bolt but its a life saver on the rear 2 plugs. And the best way to get at the rear plug on the pass side is from under the car with LT's. the driver sides a BREEZ
AlaskaZ28
Apr 17, 2015 08:54 AM
themushine
Sep 3, 2002 10:02 AM
themushine
Sep 3, 2002 10:01 AM
JasonD
Jul 29, 2002 01:46 PM
